Schumacher Corner
Hey Bob thanks for the info will try it tonight at Pratice.
just a quick question,
With a bumpy track should should I go softer on the springs and higher on the oil weight. or softer in both. the rear end seems fine, the front seems to be bumping around a bit.
Softer on the springs and heavier on the oil will really slow down the reaction a lot. I'd try running the same oil first with a softer spring. This way the dampening will stay the same but the rebound will be less and that's what causes the bounce on a bumpy track. If it's still not enough, go to the next weight up on the oil.
TURBO DoG! PMYH
Originally Posted by pucho
Yeah! and a thick cloud of polen that's pissing me off!!! thath's what my eyes look like, and this is how my nose feels
Hey TP,
Do you want to run 12 this weekend? I was going to run it but I think im going to do stock instead. Let me know. I got new bearings and such to rebuild the rear end.
R.
R.
I need a setup for the mission on high bite track don't know what the car has waiting for the mail, would like something to start with
I plan on running 1/12th and 19T Sedan.
I plan on running 1/12th and 19T Sedan at the Fast Lap State Race.
Originally Posted by Sanabria
LOL your car was green when it came off the track...is your nose green too?
hey guys,
i went for a test and i need more grip in the rear. as i power out of a high speed corner(low grip) the rear end slides out any suggestions?
i was thingking a front sway bar just to even it up any ideas?
More droop/up travel in the front. That will fix that right up.
But consider how much droop you have in the rear as well. Maybe your transfering too much weight forward and its not coming back quick enough.
Has there been any plans made for BMI to come out with an EC chasis?
Probably not such a need at this point, as the E.C is pretty sorted
I know Jason's looked into it. But he's busy with other stuff right now. Plus, he'll only make a chassis if there's something that can be improved. So a few things would need to be tried and tested before anything would be done.
Jason won't make a chassis unless he can find a genuine improvement. Last time I talked to him he said he couldn't think of anything to change on the Rubber or Foam car.
Like Jon said he is concentrating on cars that need help
