Schumacher Corner
hey quick question to all u fast guys which is your pick
lrp tc spec
or novak gtb spread spektrum version and of course why?
cheers btw if ur sponsored please say u are
lrp tc spec
R/C Tech Elite Member
I personally run the LRP because it is said to be better with the Orion brushless equipment that I use. Havent tried a Novak firsthand to know for sure, but that is what I was told.. The Novak stuff seems to work fine when using a Novak motor if thats what you plan on using.
i have the novak and the lrp, i like the lrp better, easier to setup, and when changing to brushed motor, less wiring hassle.
Got to run my "big track" setup today on a med size track and it was still awesome! Not sure if anyone has had a chance to try it, but it's the best setup I've had in years
This sucks...I used to just walk over to your desk and you'd hand it to me...lol!
so who took over pw's job as a pro driver?
also is it true schumacher are releasing light weight mi3 bulk heads red it a few pages back?
The guys at Schu USA are not hard core racers but PW and I are still here on Schu Corner along with the rest of the Schu drivers around the globe to offer support and share info.
That said Shawn Palmer has done some great things to get the team more organized so everything is looking good.
oh so he will still run schumacher at majors?
sorry i think im a bit slow today
Here is a killer big track/med-high bite setup for the Mi3
Side notes: Used Muchmore rebound foam (2 whites per bladder) in front and rear shocks and MuchMore green o-rings.
Mi2EC arms front and rear.
Carefully drilled middle hole on steering blocks.
Front swaybar is mounted using the EC mounts (used front bumper screws).
PW...what would you change on your big track setup for a bumpy med track?
They don't look too different, they are slightly narrower, so extra shims have to be used to keep the pivots etc where they normally are and they are made froma better alloy.
Where the motor mounts, instead of having the large oval with slots in it most of that metal is missing and you just get two slots for the motor screws.
Should have taken some photo's Doh!
Skiddins
Jonny Dronfield told me it needed extra shims to keep the same set up, but after speaking to Phil Booth he said that they cannot be narrower, as the eccentrics for the diff wouldn't fit. So no extra shims are required.
Jonny
