Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 01-02-2006, 12:15 PM
  #12586
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Pics PW!!!!
Rod
RKeasler is offline
Old 01-02-2006, 12:24 PM
  #12587
Originally Posted by RKeasler
Pics PW!!!!
Rod
Rod,
Paul posted Pics of his car on the bottom of page 416. I hope this is what you were looking for
Later
Jim
jimnew is offline
Old 01-02-2006, 03:12 PM
  #12588
RKeasler's Avatar
Nah, that's the Carpet version I want to see the regular EC
Rod
RKeasler is offline
Old 01-02-2006, 03:33 PM
  #12589
Not great pics, as the lighting wasn't so cleaver.
On a side note, has anyone (Paul??) fitted 64dp spur gears yet?? What's the easiest method. Looks like there is plenty of room (tried it!) for both Kimbrough or Xenon, just needs the holes countersinking/Counterboring.
MattW is offline
Old 01-02-2006, 03:51 PM
  #12590
dont shoot me but what is the difference between carpet spec and the normal mi2ec??
aus jd 2703 is offline
Old 01-02-2006, 04:28 PM
  #12591
hi guys jsut finished building my EC just got to get sum bits in it now
talk of this droop what do u recon i use the schi gauge witch sits the chassis on 10mm blocks start at about 3mm front 4mm back to start?
bob33 is offline
Old 01-02-2006, 05:44 PM
  #12592
I have a RW spur mounted in my car right now, 114. Looks like you can get 118 in the carpet spec.
You do have to countersink the gears , but i was told that Schumacher should have a fix for the guys running 64 pitch soon
The RW spurs work the best because they are flat and won't bow when you try to countersink them.
Hope this is what you were looking for
Later
jim
jimnew is offline
Old 01-02-2006, 06:04 PM
  #12593
mini-dub's Avatar
Trader Rating: 16 (100%+)
I just finished building my carpet spec EC and put a 118t RW 64p spur on it. It sticks down into the cutout in the chassis but it looks like there might be enough room to put a 120. Don't hold me to that though as I didn't try it but a 118t fits easily. I just countersunk it with a couple stone dremel bits.
Bob - The setting on the droop gauge changes with tire diameter. Set the car to have about 2mm uptravel and then take off the wheels and make sure it's even right to left.
mini-dub is offline
Old 01-02-2006, 06:27 PM
  #12594
RKeasler's Avatar
I am going to keep my Mi2 even after getting the EC so as far as 64 pitch goes to get the RW spurs to fit what do I need other than the spur.
Rod
RKeasler is offline
Old 01-02-2006, 06:37 PM
  #12595
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Rod
Rod- YGPM
Jon Kerr is offline
Old 01-02-2006, 08:54 PM
  #12596
RKeasler's Avatar
Thanks Jon just put in the order a little while ago.
Rod
RKeasler is offline
Old 01-02-2006, 10:01 PM
  #12597
A Ilievski's Avatar
Trader Rating: 39 (100%+)
hey what tape are you using to hold ya batteru pack in. i need some to hold my 3800 packs in
A Ilievski is offline
Old 01-03-2006, 02:54 AM
  #12598
Jim, fair enough. I don't generally use RW gears, but i guess with them being so stiff makes them easy to countersink. I had a 48dp 90 in the car to check when i was building, that equals 120 64 Was very close to being right through the cutout, would be fine i would guess for you guys with an extra 0.5mm on the chassis, but not sure i'd risk it. 118 should be fine though.
Kid TT, that is Xenon tape (I think!), very strong, but very expensive.
MattW is offline
Old 01-03-2006, 10:24 AM
  #12599
STLNLST's Avatar
Trader Rating: 32 (100%+)
I need an EC
STLNLST is offline
Old 01-03-2006, 01:54 PM
  #12600
King-G's Avatar
Mine lands today, has been sitting at UPS H.Q over the New year period!
God damn getting Ancy!
King-G is offline
