Schumacher Corner
Yes sanding the rings with 600 grit does make a big difference - i've been doing this for a long time. So far i would say that is the single biggest improvement i have done to diffs.
Might try some CA on them, i don't know - i have a brand new diff sitting on my bench at this moment..........hmm
Sand and glue is the best!
hey are there any tips on getting the cir clip out of the diff out drive?? holds the thrust bearing in last time i tried i broke one and righ now i have no spares? i tried to use and automotive circlip tool but the tip was to big is there something else i can do please help dont feel like wait for a week for ascrew kit to come from other side of australia
I used a pair of straight body scissors and dremeled the tips into a point that will fit the c-clips. They suck for body scissors now but you can still cut other stuff with the back of the blade. They work really well for removing c-clips though.
Trader Rating: 32 (100%+)
I bought an inexpensive circlip pliers from Dick Smith Electronics.
I had to file a small portion off the tips to fit the schumacher circlip hole size, but they work perfectly and cost me just a few bucks
hey do you guys seal up your batteryholder with ca?? i know your ment to sand and then putdrops of super glue on the chassis but do u guys do it to the battery tray and strap??
I personally dont bother C.A any of my chassis edges..I sand them round, and use wed / dry fine grit to give a glass like finish to the edges.
I havent had a problem with delaminating chassis in the time Ive raced.
I figure a hit hard enough to delaminate a rounded edge would still damage one with a thin layer of C.A.
I do file the edges of the battery slots slightly to prevent it cutting the cells shrinkwrap.
hey guys what soldering iron do u reckomend to do battery building and general wiring and repairs? 60watt or 80 watt or 100watt??
and why? is a temp adjustable iron wether waiting and saving for??
You'll want to get the best iron you can get with the widest tip you can get. An adjustable temp iron like the Hakko 936 that I use is nice but not a necessity. I used a Hakko 80 watt iron for a long time. It's cheap, comes with a big wide tip that's perfect for doing batteries. The key when doing batteries is to only have the tip on the cell for 1-2 seconds. You don't want to heat up the cells too much or you can damage them.
For battery assembly you should get a 100W 700'F (or an 80 Watt like Jon said) soldering iron with a 1/4 tip. The WELLER 100P is a very goood sldering iron to do packs. You can do most connections in less than 2 seconds.
For eveything else, any good station will do.
You do not want to use a lowwattage station to build batteries unless you are very good at soldering. The longest time you want to keep an iron on as battery tab is 5 seconds. After that you are asking for trouble.
You do not need more than 50W for general soldering like wires to the ESC and to the motor.
60/40 solder melta at around 420'F and Silver solder at around 470'F
What you need for battery/tab soldering is an iron with enough POWER not heat.
does the pro diff rebuild kit in clude a pro thrust bearing or just a standard bearing?
MI2 bith BMI Chassis
Does anyone here have a base setup for a BMI2 on asphalt with rubbers? Has anyone here been able to compare the handling of the BMI2 to the EC? Id be interested in knowing the diffirence. I just got my MI2 a short while ago and have only run it once with foams and it felt realy great but we have a club race this weekend and Im going over to rubber so would apreciate any help that you may be able to give me.
Set up
Marcos has a hot set-up that he ran this past weekend.
Shot him over a P.M. and I'm sure he will help you out.
http://www.rctech.net/forum/member.php?userid=8722
