Schumacher Corner
yes
Can Custom please check I've done this right.
As I don't know your real name etc I've left some bits blank.
'Customs' IIC Setup
Please tell me if anything is wrong and I'll correct it.
Skiddins
'Customs' IIC Setup
Skiddins
both fdr 7.20..btw my name is Kevin Bottoms
R/C Tech Elite Member
I bought I load of Lunsford Ti screws, byt the time they were shipped to the UK it certainly wasn't cheap.
A Week after I got them Schuey anounced their Ti screws and prices....would have waited if i'd known
Skiddins
Skiddins
OK, this should now be correct, all the origianl links work as I haven't changed the name of the file;
'Customs' IIC Setup
Skiddins
'Customs' IIC Setup
Skiddins
many thanx to Kev and Damian...
when do we need and how you can measure the 20% rebound?
If your car is loose and oversteer what can you change first?
cheers
cheers
Just add up full set of ceremic bearing,wow!it's smooth!
i had done some modification on the chassis,this to prevent small rock stuck between the rear diff and chassis that cause the rear belt to snap!I'm running lower diff setting.
car
try the mazda 6 body, less dope on the frt..I found with this setup if u dope full frt's it will b loose ..if anything u will push a bit off power...
if the car reacts to fast for u go up in oil 50wt ..for me a car that reacts too fast is loose ....play with spring rates go up and down frt and rear... for me I like a small push that way u can run more dula rate 70 to 80% that way the car will rotate fast and not loose traction....the main thing is to try 1 thing @ a time......update me/us on how it works ..My local track is not open yet so I only have iic wheel time
I was using the setup that jimmy has sended long time ?ago it was ok but last week I go to another club to race, their carpet was a bit funny ,it was very low grip I normally use R27 tyres but only managed B final with r22s...
I'm not sure what setup jimmy had then.......this setup is up to date.. can U run 27frt 22 rears ? ....on low biet try less droop say 3 rear 4 frt on hudy guage ie:more up travle like 5mm in the rear and 4mm in frt..
New name, same great taste
Tech Legend
Trader Rating: 51 (100%+)
Just for reference . . .
With Marc's old setup before Vegas Marc could turn an 11.6 FL with his 19t.
Today he made us all look like rookies putting everyone (he was the only one not running a 13.5ss) a lap down and running his handout CO27 from vegas. He bettered his own PB by about a lap, and hit a bunch of 11.9's and 12.0's even at the end of 5 minutes.
He might be a little modest, and a good friend for suggesting others had something to do with this setup, but make no doubt . . .That guy can wheel a car!
does schumacher have any plan to make and sell diff dust covers? itd be nice especially for aphsalt drivers. i dunno maybe our tracks over here are dustier than most but itd be nice
Custom...you're from IL right? Just wondering if I remembered that right and what your local track is.
This is coming up if you are close or anyone else nearby. Schumacher is one of the sponsors.. http://allstarcarpetseries.com
* TeamHurricane.net
* Trackside
* His and Hers Hobbies
* Victory R/C Hobbies
* Parma International
* P-Dub Racing
* RCTech.net
* Hobbico
* Hyperform Racing
* Novak
* Schumacher
* TeamHurricane.net
* Trackside
* P-Dub Racing
* RCTech.net
* Hobbico
* Hyperform Racing
* Novak
* Schumacher
oooooops
'Customs' IIC Setup
Skiddins
'Customs' IIC Setup
Skiddins
