Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 10-04-2007, 03:14 PM
  #22051
Customworksking's Avatar
Trader Rating: 74 (100%+)
Originally Posted by Skiddins
Hi, trying to put your setup onto a PDF, what does the 'Short camber link' mean?
Which top deck did you settle on?
Tyre Warmers?
Additive?
Can't think of anything else at the moment
run the rear camber link short u have 2 settings inner and outer run the outer
I ran the kit top deck but jimmy ran the stiff...no warmers no need ...as allways corally jack the gripper .....pic of the camber link
Customworksking is offline
Old 10-04-2007, 03:48 PM
  #22052
yokemad's Avatar
Is there any chance to fill the Setup Pdf cos After that picture I'm kind of Lost
yokemad is offline
Old 10-04-2007, 04:12 PM
  #22053
Wink ??????
going off the setup sheet all u need to know is link washers (horizontal) 2mm
ok now u have 2 holes in the rear hub run the hole on the inside not the hole that is deeper in the wheel..now u get me?
Old 10-05-2007, 02:52 AM
  #22054
James khoo's Avatar
Trader Rating: 15 (100%+)
Just to ask,is there any way Schumacher came out a purple bulkhead,it going to look good!
James khoo is offline
Old 10-05-2007, 04:31 AM
  #22055
Skiddins's Avatar
I'll try to fill in the rest of the sheet tonight then post it for 'Custom' to check.
Skiddins
Skiddins is offline
Old 10-05-2007, 04:40 AM
  #22056
Skiddins's Avatar
The prototype had purple bulkheads, but it had too much purple on the car.
Most people think they look better now!
Skiddins
Skiddins is offline
Old 10-05-2007, 05:58 AM
  #22057
yokemad's Avatar
I've bought some cvd dogbones and they are silver not purple
yokemad is offline
Old 10-05-2007, 08:07 AM
  #22058
I seen 1 that was all black it was killer
Old 10-05-2007, 08:09 AM
  #22059
Mr. McGoo's Avatar
Trader Rating: 23 (100%+)
ok, i fixed all of my mistakes on my previous setup and here is my complete Vegas setup...if you have any questions feel free to shoot me a PM....
Mr. McGoo is offline
Old 10-05-2007, 09:19 AM
  #22060
Theh "purple" car kind of looked ok for a start, but it really was too much!! better as they are now, and even better looking with the l/w bulkheads
MattW is offline
Old 10-05-2007, 09:57 AM
  #22061
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
The new LW bulkheads will be anodized black, they should look great with the purple accents throughout the car.
Randy Caster is offline
Old 10-05-2007, 10:35 AM
  #22062
chris72983's Avatar
When is there release date?
chris72983 is offline
Old 10-05-2007, 11:10 AM
  #22063
stegger's Avatar
Has anybody had any problems with the schumacher titanium inner hinge pins? I changed to them thinking that they would be stronger than the standard steel ones!!! on sunday last i got punted off by a back marker at the end of a straight right into the boards after the race i got the car back and i feared that i had broken the front and rear wishbones, but the inner hinge pins had bent into a "S" shape I suppose it's cheaper than replacing the CF wishbones I had to dremmel them in half to get them out of the wishbones
stegger is offline
Old 10-05-2007, 11:21 AM
  #22064
Trader Rating: 42 (100%+)
boo yaa
Nexus is offline
Old 10-05-2007, 11:50 AM
  #22065
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
stegger try these hinge pins from losi LOSA6094.
Ron Goetter is offline
