Xray T1
Of the cars that were developed in the last year or two, no one is better than another on the professional level. Sometimes the car that comes w/ the best instructions is the best car on the track b/c you make less mistakes building it. For that reason, I would say the Xray and HPI are the two best cars. The XXX-S and TC3/4 are becoming outdated, due to the fact that other companies can CAD design a car with much smaller tolerances for error. Now between the Xray and HPI, I would say the HPI is the better overall car, because it's durability and ease to work on. I'm sure the Xray fellas are going to jump all over me about that, but shaft drive is much simplier than two-belt design.
Thanks guys! Never though of shaving a little material off the shock retainer. Everthing is set right, so that's not a problem. But last night I put a pair of alum. retainers on bottom and that helped a lot! I've used those in the past just didn't feel like taking them off another car for the other on. But I'll definatly try the AE retainers in the back. If that doesn't work, look out Team Tamale!!
I can't understand why you can only get 7-8mm of ride height with foam tires. That doesn't make any sense at all.
Rob
Rob
Not jumping all over you just a lite thrashing...LOL In the last year I have owned a FT TC3, Yok CGM and the HPI Pro 4 and after all of that I went back to my Xray (now FK). The Pro 4 felt the smoothest out of the shaft cars, but it was a royal pain to work on...just change a spur gear or adjust a diff!!! Just tapping a wall with these shaft cars made me crinch due to durability issues.
The Xray is IMHO the easiest car to work on as well as most durable. Again, this is my preference.
Mike
Originally posted by johnbull
What do you honestly think guys on this thread are going to tell you.
I think your decision on what car to buy comes down to rubber ires or foam tires.
Basically-all the cars-and many of the exotics (RDX, Barracuda, 415, EvoIV, etc...) peform extremely well on rubber tires.
I think you get into a couple more problems indoors on foam tires. ONe-is the indoor tracks are more brutal-causing more breakage. YOu ave fitment issues with wide foam tires (28mm vs 24mm for rubber tires), making ride height, roll centers diifferences, no front diffs or spools-just one-ways. INnner diameter of foma tires is smaller-so have fit issues with upper ballstuds...... The list goes on and on in that respect.
Also-a very big difference is foam/Ozite set-ups are very well established on the TC3 and XXXS-G+. And lately set-ups are starting to emerge for the XRay too. The Pro4 has started to perform well after a year on carpet. It takes time to dial in set-ups for the "other" cars out there when only a handfull of guys who are on the net run them and truly have the ability and knowledge to test set-ups. Look at the TC4-top TC3 drivers have struggled with the TC4 so far-but that wont last long.
Another thing that is interesting-the only car in my opinion thats shaft driven that has an adavnatge over a belt car because its a shaft drive car is the Associated TC3 (4). The CUda, Pro4 and Tamiya EvoIII have no more rip than any belt drive car-in fact-they all almost accelerate smoother than belt cars in my opinion. Smooth being a nice word for slower. This on Carpet mind you. I dont know why this is-maybe only TC# has just the right hardness of material and cut of gear to make the shaft drive thing work. Maybe its there diff case design and hardness that helps. And dont let the free spin trick fool you-the Pro4 and Cuda and Tamiyas shaft drive cars spin faster and longer than the Tc3 right out of the box in a big way-Trust me i know-Ive seen or owned them all.
Last-I truly think that if youve got rubber tire asperations-you can take any of the top of the line cars and be competitive. But for carpet on foams-you need to decide if you want somethng thats established as fast or want to forge your own way.
And rubber tires guys-dontr whine because if you do-youve missed my point. This is no rubber tires vs. foam tires.
Hi guys:
Do you know where I can get a set of drive shaft raplacemet plastic caps? I lost one and haven't been able to get it anywhere, part# 30 5240. please help! thanks a lot.
Omar R.
Omar R.
Quiet,
Try Stormerhobbies.com,they have them in stock.
Hi guys (and gals)...
Does anyone know where I might be able to get an X-Ray T1FK? I'm looking around for a friend of mine, and we can't find them anywhere (well, that and RC America is closed for the week).
We'd like to get it in a hurry if possible... so if anyone can help, please post!
Thanks!
Thanks!
Thanks!
Thanks!
Dom
Cool... thank you!
Originally posted by Quiet
Hi guys:
Omar R.
Hi guys:
Omar R.
Ashford hobbies has just about everything that a person needs for their Xray. Check them out at:
www.ashfordhobby.com/pricing013.htm
Mike
Will teamxray.com ever get their e-shop going ro with that link always lead to an advertisement. It would be nice if I could find out if Xray is going to have their own e-shop that will ship to the USA.
Greg, you have pm.
Originally posted by Michal101
Omar,
Mike
Omar,
Mike
