Like Tree3Likes
Xray T1
Old 01-07-2005, 12:17 PM
  #11131
Associated sells specific motor screws. I use 3x8mm flat head screws and then use countersunk washers and never have a problem with losing them.
NismoSkyline17 is offline
Old 01-07-2005, 01:09 PM
  #11132
NVisible's Avatar
nice!. thanks a lot
NVisible is offline
Old 01-07-2005, 05:12 PM
  #11133
NVisible's Avatar
for my next question, Pball or C Hub?
Im guessing C Hub since thats whats on the FK. does one have advantages over the other?
NVisible is offline
Old 01-08-2005, 06:16 AM
  #11134
John Fontaine's Avatar
You can't put pillow ball suspension on the new FT kit due to the bulkheads. Pillow ball is primarily used for Nitro touring cars. People do tend to like the pillow ball for outdoor asphalt racing, but C-hub really shines indoors where the tracks are tighter.
John Fontaine is offline
Old 01-08-2005, 06:50 AM
  #11135
www.microfastners.com
IMPACTPLAYR is offline
Old 01-08-2005, 07:11 AM
  #11136
mazmorbid's Avatar
Trader Rating: 11 (92%+)
I thought it was "FK", and "pivot ball" am I missing something ?
mazmorbid is offline
Old 01-08-2005, 07:35 AM
  #11137
NVisible's Avatar
thanks. i was assuming c-hub was the better of the two because thats all you can use on the FK. Guess i know what im doing today
NVisible is offline
Old 01-08-2005, 09:43 AM
  #11138
duckman996's Avatar
Trader Rating: 14 (100%+)
The choice between C-Hub and pivot-ball is up to you ....
Pivot-ball is more durable and holds is settings better then c-hub (through my experience), while C-hub is lighter, and tends to react quicker. The factory-team has the shorter arms, while the EVO2 that you have has the longer-arms.
FYI - You can mount a pivot-ball on an FK ... you just have to purchase the short pivot-ball suspension.
I would suggest that you stay with the pivot-ball at this point until you get used to the car - I am sure that you will find the added durability a blessing.
duckman996 is offline
Old 01-08-2005, 09:54 AM
  #11139
ChrisP's Avatar
FYI....you cannot mount the pivot ball on an FK, as the upper mounting points for the pivot ball suspension have been removed from the FK bulkheads
ChrisP is offline
Old 01-08-2005, 08:58 PM
  #11140
duckman996's Avatar
Ahhh yes you are correct ... I confused my FK with my Evo2
Old 01-09-2005, 01:38 AM
  #11141
Quick question for you guys running the FK. How are your servo's mounted? I had to mount my servo on the backside of the mount which makes it stick way out. Did you guys drill new holes for the mount? I'm using an Airtonics 357. Any picture showing the setup will be much appreciated. Thanx
- Stan
skinart76 is offline
Old 01-09-2005, 06:53 AM
  #11142
JDXray's Avatar
- Stan
Here is a pic of mine.
And here is a servo shot.
Jon
JDXray is offline
Old 01-09-2005, 07:48 AM
  #11143
Default spur gears
i,am looking for 64 pitch spur gears that will fit fk.
can any tell will i would be able to find some.
thanks
zinger
zinger77 is offline
Old 01-09-2005, 08:02 AM
  #11144
Default set up
what spings and foam tires are people running on carpet?
thanks zinger
zinger77 is offline
Old 01-09-2005, 02:06 PM
  #11145
JDXray's Avatar
Default Re: set up
thanks zinger
Look up above those are the springs i use. Purple/Violet. As for Tires.
TRC Purple/Plaid
Jaco DBL Pink/Org, DBL Pink--- Orange/Purple and Purple
BSR- ^
JDXray is offline
