Like Tree3Likes
Xray T1
Old 12-18-2004, 05:28 PM
  #10846
TeamButter's Avatar
TimXLB-Did I miss a Team newsflash? "We make..." Not being sarcastic just curious..are you now involved with the ownership aspect of BMI?
Hope everyone has had/will have a good weekend of racing.
Looking forward to the Novak race!!
Butter
TeamButter is offline
  #10847
Another question to bug you guys with. I wanted to use a shorter front camber link and the turnbuckle just doesnt want to thread any further. I have the correct one on but it just seems too long. I can only use the longest front camber link setting. Am I missing something?
JimMcClure is offline
Old 12-18-2004, 05:29 PM
  #10848
TeamButter's Avatar
There are shorter camber links available...Not sure of the measurement......
Anyone else wanna chime in?
Old 12-18-2004, 05:32 PM
  #10849
ChrisP's Avatar
There are 30mm turnbuckles....
I have some on backorder..
the standard ones are 35mm...
I tried using AE 4-40 pieces, but they were just a little too undersized to hold securely
ChrisP is offline
Old 12-18-2004, 05:33 PM
  #10850
Brian McGreevy's Avatar
Jim,
You must have put the rears on the front. You should be able to use the shortest link position with the right turnbuckles.
Brian McGreevy is offline
Old 12-18-2004, 05:38 PM
  #10851
There are 25mm turnbuckles available.
303200 Adj. turnbuckles 25mm L/R w/ends
303210 Adj. turnbuckles 25mm L/R w/o ends
Hondaguy is offline
Old 12-18-2004, 05:49 PM
  #10852
ChrisP's Avatar
Gonna hafta getme some of those
ChrisP is offline
Old 12-18-2004, 05:54 PM
  #10853
Well I just checked it. The turnbuckles I have on the car are 30mm. When they are threaded all the way in, in the shortest camber link hole I have about four degrees of positive camber.
Old 12-18-2004, 06:01 PM
  #10854
rayhuang's Avatar
OK-guys-I just had a racing day from hell. 8x1 and my Xray. Didnt break a thing, but clobbered boards left and right!! Tamale c-hubs-Perfect. No crap!!
If they survived today-then its all good.
Ray
rayhuang is offline
Old 12-18-2004, 08:38 PM
  #10855
GMartinez's Avatar
Trader Rating: 91 (100%+)
I been thinking of getting the T1FK for some time now but I would like to how much difference is there from the new kit & old one.
It seems like everyone in my area has converted from losi,tc3 to the Xray I've been stumped between the T1FK or the new JRXS I am currently racing with the Pro4 & have done well but the new cars lookso smoother thru the onpower turns.
GMartinez is offline
Old 12-18-2004, 08:42 PM
  #10856
duckman996's Avatar
Trader Rating: 14 (100%+)
If you donlt tag the wall too much, you can use Tamiya 415 turnbuckles ... they should fit no problem and they have 30 mm alluminum ones.
duckman996 is offline
Old 12-18-2004, 09:09 PM
  #10857
Butter
No news flash, I was the one who helped with the Xray chassis(s) along with the ETC3 chassis. as for having any part of ownership...........one can hope.
we are trying to get the time off for the Novak race..........but it's not looking good at tis point as for racing we never made it to the track. spent most of the time just trying to stay on the road. it was raining and then turning to ice as soon as it hit the road. over 20 cars and trucks off the road in less than 5 miles.
RAY:
got your PM it's going out Monday AM. thanks for posting about the TAMALE "C" hubs I might be getting some soon. will call Monday also.
TimXLB is offline
Old 12-18-2004, 10:42 PM
  #10858
danjoy25's Avatar
Trader Rating: 38 (100%+)
Default Pic of my FK
with a Hacker 6 turn and U-force 75 ESC
danjoy25 is offline
Old 12-19-2004, 03:01 AM
  #10859
MrRolla's Avatar
Trader Rating: 30 (100%+)
Default Time for a rebuild over Xmas break
Hi guys,
Since i have a month off racing im going to tear down my FK and rebuild it. This will be my first time rebuilding the rear diff and im aware you need a special tool to do it??
Is the HUDY caster clip remover tool what i need? Also will i need to buy any spares that might break easily or will be worn when i pull apart the diff?
Also i seen some bearings for an xray on ebay for $20US are these ok to use and will they run the same as the standard bearings or should i buy genuine Xray bearings?
All help appreciated
Cheers Dave
MrRolla is offline
Old 12-19-2004, 03:28 AM
  #10860
where can i buy bmi chassis peices cause i've broke a bumper and battery hold down strap. another question. who sales the aluminum rear chubs. also need fk complete shocks.
hoook me up.
Beddow
tc3Guru is offline
