Xray T1
#721
Thistle, You glue the TOP piston to the shaft, that will allow you to properly adjust the shocks.
And yes, the only O-ring I have ever found that works on the bottom shock seal is the Serpent style O-ring. Which by the way I do have in stock.....hehehe
#722
Ahh crap. I mixed all my extra o-rings with left over o-rings from my Losi and AE cars. NUTS!!!!!
I am sorry that I told you the wrong Info.
Mike Webb
Mike Webb
#723
Can you put a samll drop of CA on the Plastic Pillow Ball Guides that fit into the 5mm screws that go into the Steering blocks and the rear Blocks? I think that I kind of messed up the threads on the blocks because I took one apart last night to adjust something and when I screwed it back in the Plastic guide did nto go into the Aluminum 5MM Screw correctly and that is when I messed up the threads.
Mike Webb
Mike Webb
#725
Sorvo saver
Hey all of you X ray owner, have you guys notice that the servo saver is a bit weak? Maybe it's just my car but are there any stronger spring out there that I could use to stiffin up my servo saver?
#726
I have not had a problem with the saver. I don't think there is an option for a stronger spring. I will have to browse myTSN for that possibility.
I don't recommend this crude method but you could stretch the spring yourself, but that will change the spring rate drastically for the worse or may be what you are after.
#727
RCCadet-
Yup. I had it lined up and when I started screwing in the metal hexnut the Allen Wrench went all the way through and moved the plastic part a little and when I started to tighten it the lip that fits into the Hex was not lined up so I crushed it a little. I then took some rubber cement and just touched it to the plastic cup and put it into the Hex to hold it there and make sure it was in and then I screwed the piece in. It was very hard to turn in and that is when I found out that I messed up the threads because one part of the Hex would go into the block quicker the the other end of the hex.
Mike Webb
Mike Webb
#730
I guess I am going to go visit buster again today ... He is going to think I don't know how to put a car together .
#732
Buster,
would you happen to have the following xray options in stock?
1:Graphite upper holder for precut bumper
2:aluminum roll center bridge
The xshop seems to be sold out on the above options.
#733
Best Digital Servo
need your guy's thoughts on the following servo's
1: Ko PDS 2143 FET DIGITAL metal gears, 114 oz/.08 sec
2: Ko PS 2173 FET metal gears, 114 oz/.09 sec
3: Airtronics 94755z DIGITAL HIGH SPEED, HIGH TORQUE-81 oz/in @ .11 se
#735
Re: Best Digital Servo
