Old 02-21-2002, 04:23 AM   #721
Buster Bennett's Avatar
Send a message via AIM to Buster Bennett
Thistle, You glue the TOP piston to the shaft, that will allow you to properly adjust the shocks.
And yes, the only O-ring I have ever found that works on the bottom shock seal is the Serpent style O-ring. Which by the way I do have in stock.....hehehe
Buster Bennett is offline   Reply With Quote
Old 02-21-2002, 07:11 AM   #722
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Ahh crap. I mixed all my extra o-rings with left over o-rings from my Losi and AE cars. NUTS!!!!!
I am sorry that I told you the wrong Info.
Mike Webb
mike_Webb is offline   Reply With Quote
Old 02-21-2002, 08:13 AM   #723
mike_Webb's Avatar
Can you put a samll drop of CA on the Plastic Pillow Ball Guides that fit into the 5mm screws that go into the Steering blocks and the rear Blocks? I think that I kind of messed up the threads on the blocks because I took one apart last night to adjust something and when I screwed it back in the Plastic guide did nto go into the Aluminum 5MM Screw correctly and that is when I messed up the threads.
Mike Webb
Old 02-21-2002, 08:23 AM   #724
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
You mean the plactic cup that sits between the pillow ball and the metal hexnut? It was not seated when you tightened the hexnut?
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 02-21-2002, 08:25 AM   #725
Vue Vang's Avatar
Sorvo saver
Hey all of you X ray owner, have you guys notice that the servo saver is a bit weak? Maybe it's just my car but are there any stronger spring out there that I could use to stiffin up my servo saver?
Vue Vang is offline   Reply With Quote
Old 02-21-2002, 08:31 AM   #726
I have not had a problem with the saver. I don't think there is an option for a stronger spring. I will have to browse myTSN for that possibility.
I don't recommend this crude method but you could stretch the spring yourself, but that will change the spring rate drastically for the worse or may be what you are after.
V-Dezign 4.0
Old 02-21-2002, 08:31 AM   #727
mike_Webb's Avatar
RCCadet-
Yup. I had it lined up and when I started screwing in the metal hexnut the Allen Wrench went all the way through and moved the plastic part a little and when I started to tighten it the lip that fits into the Hex was not lined up so I crushed it a little. I then took some rubber cement and just touched it to the plastic cup and put it into the Hex to hold it there and make sure it was in and then I screwed the piece in. It was very hard to turn in and that is when I found out that I messed up the threads because one part of the Hex would go into the block quicker the the other end of the hex.
Mike Webb
Old 02-21-2002, 08:33 AM   #728
Mike::I had to look at my cars and I think you will need to buy new steering blocks or uprights, which ever was damaged, and do not use CA.
Get ahold of Buster and replace the part in question.
V-Dezign 4.0
Old 02-21-2002, 08:39 AM   #729
Aaahhh, IC now. If there are damaged threads replace the part. Asfor the plastic retainer it may be reused if not too badly mangled. They seem soft enough that when seated properly they will form themselves around the ball as required.
V-Dezign 4.0
Old 02-21-2002, 08:45 AM   #730
mike_Webb's Avatar
I guess I am going to go visit buster again today ... He is going to think I don't know how to put a car together .
Old 02-21-2002, 08:46 AM   #731
LOL!!
V-Dezign 4.0
Old 02-21-2002, 09:54 AM   #732
Buster,
would you happen to have the following xray options in stock?
1:Graphite upper holder for precut bumper
2:aluminum roll center bridge
The xshop seems to be sold out on the above options.
pisnonvtec is offline   Reply With Quote
Old 02-21-2002, 09:58 AM   #733
Default Best Digital Servo
need your guy's thoughts on the following servo's
1: Ko PDS 2143 FET DIGITAL metal gears, 114 oz/.08 sec
2: Ko PS 2173 FET metal gears, 114 oz/.09 sec
3: Airtronics 94755z DIGITAL HIGH SPEED, HIGH TORQUE-81 oz/in @ .11 se
Old 02-21-2002, 10:02 AM   #734
Trips's Avatar
Trader Rating: 16 (100%+)
I've been using the KO 2143 exclusively in all my touring cars and it's done an excellent job for me. The 2173 is a non-digital servo, but is also a great choice.
I haven't used the 94755, but I've never had a problem with any other Airtronics servo.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 02-21-2002, 10:04 AM   #735
Default Re: Best Digital Servo
Go for the PDS 2143! I use the PDS 2123 and look forward the getting the 2143 for my second T1.
V-Dezign 4.0
