Xray T1
#6631
No, it doesn't.
#6632
Short arms
I was just wondering if the short arms come in soft, med, and hard as well,anyone know off hand??
#6636
Re: Short arm conversion
Originally posted by forty6
I'm trying to find the info on this thread but I can't seem to find it.
What parts does one need to convert a T1R to short arms? Is it as simple as replacing the arms and putting the mounts outside of the bulkhead? Thanks.
#6638
Registered User
pace72 I am pretty sure you can use the droop screws in the rear.I don't really see why not, it's the same car but not graphite.
#6640
Originally posted by Pace72
i want to know if the new factory kit come with the spring steel hub for the wheel??
thanks
Pace
thanks
Pace
I have seen some closeups of the new car and it looks very nice with all the refinements present, but a major let down IMO is the lack of SS Hubs.
#6641
Just be careful when you dremel away material that you alter the tweak of the car.
#6642
Re: Re: Short arm conversion
anyone
anyone
#6643
Looking for a good, high speed outdoor, rubber tire setup for stock with short arms. Dug around on mytsn but didn't get pas the garbage.
Anybody have a good one?
Links?
thanks!
Links?
thanks!
#6644
Re: Re: Re: Short arm conversion
Originally posted by sands
Asside the short arms, you'll need to cut the aluminum suspension pin holder part in half. Both front and rear. Or you need to get the all plastic ones from the T1R. or you need to order the smaller, aluminum nut inserts from the Evo kit.
#6645
Pitures of Setups on Electronics
I need to see some pictures of other peoples setups on the electronics. I need to figure a nice and neat way to put all those wires around in my car. What i am saying is where the reciever,esc,servo wires go. In my T1R i have had it running for a bit now, but i still think there is a better way to put all those wires. If you know what i am talking about could you please show me some easy pictures of where to put these wires.
Thank you
Jon
Thank you
Jon
