Xray T1
#6481
Guys.
here is what i run.
Tamiya Type RR 23t - Final Drive Ratio = 5.6 - 5.8
Reedy PT 10t x 2 - FInal Drive Ratio = 8.5 - 8.8
Reedy KR 11t x 2 - Final Drive Ratio = 7.9 - 8.3
Ok. Here is my questions. Do you think my final drive ratio is correct? I don have problems with my motor. But it is very very hot. Do you think i need to go up a little on my ratio?
Kinda worried about the temp on the esc too. Its reading around 56 deg C to 61 deg C for both the Reedy Motor. Is this normal?
I am using Keyence V Zero Extreme '02 on my EVO 2 FOC with internal drive ratio of 2.125. Hope someone can advice.
TIA
here is what i run.
TIA
#6483
Originally posted by AdR|aN
Guys.
here is what i run.
TIA
Guys.
here is what i run.
TIA
#6484
Originally posted by Neil Rabara
Aside from your questions, what does your signature exactly mean?
No intention of insulting anyone out there.
#6485
Has anyone tried the short arm conversion on asphalt? Also what is the part number for the new bulkheads.
#6486
I didn't know there was a short arm conversion avalible, I always thought you had to buy everything seperate. But since there is one could you post the part # for the short arm conversion?
thanks
thanks
#6487
there is not conversion kit, you just have to purchase the parts separately. and there are no part number for the bulkheads at this time. Xray said they will be available at some point
#6488
Okay sorry for the wording, has anyone put short arms on their XRAY and ran asphalt.
#6489
The arms are great. I feel like the car is much more responsive with them. I've yet to run them on a large fast track like Parkersburg WV ( www.ovrccc.com )... but I'm guessing they'll be just fine there too.
I know a couple guys that run regularly at YCity. Guys from OVRCCC. I've run at the Y a time or two myself and you are right... one of the best track owners around.
#6490
just wondering but what is a good starting point for gearing should i use with an 8x2. Also, im using the stock pullies
#6491
I have used the short arms on asphalt for a few weeks, it took some setup change to get it right. The biggest difference that I noticed was a mid-corner push with my existing long arm sertup. Once I got things worked out the car had tons of low speed steering and was super reactive. It also transitioned much quicker in chicanes.
#6494
Is there any other place to get xray parts other than Mytsn?
10 bucks shipping regardless of what is purchased it highway robbery. What are they adding bricks to the package.
#6495
