Xray T1
Old 03-19-2004, 12:00 PM
  #6481
AdR|aN's Avatar
Guys.
here is what i run.
Tamiya Type RR 23t - Final Drive Ratio = 5.6 - 5.8
Reedy PT 10t x 2 - FInal Drive Ratio = 8.5 - 8.8
Reedy KR 11t x 2 - Final Drive Ratio = 7.9 - 8.3
Ok. Here is my questions. Do you think my final drive ratio is correct? I don have problems with my motor. But it is very very hot. Do you think i need to go up a little on my ratio?
Kinda worried about the temp on the esc too. Its reading around 56 deg C to 61 deg C for both the Reedy Motor. Is this normal?
I am using Keyence V Zero Extreme '02 on my EVO 2 FOC with internal drive ratio of 2.125. Hope someone can advice.
TIA
AdR|aN is offline
Old 03-19-2004, 01:55 PM
  #6482
RandyB's Avatar
Does anybody have pics other than the xray web site on the new car??
thanks
RandyB
RandyB is offline
Old 03-19-2004, 09:45 PM
  #6483
Neil Rabara's Avatar
Originally posted by AdR|aN
Guys.
here is what i run.
TIA
Aside from your questions, what does your signature exactly mean?
Neil Rabara is offline
Old 03-19-2004, 10:24 PM
  #6484
AdR|aN's Avatar
Heehee. Its for me to know and for you to guess.
No intention of insulting anyone out there.
AdR|aN is offline
Old 03-20-2004, 01:46 PM
  #6485
Formula1fan's Avatar
Has anyone tried the short arm conversion on asphalt? Also what is the part number for the new bulkheads.
Formula1fan is offline
Old 03-20-2004, 04:31 PM
  #6486
I didn't know there was a short arm conversion avalible, I always thought you had to buy everything seperate. But since there is one could you post the part # for the short arm conversion?
thanks
jiggamacdaddy is offline
Old 03-20-2004, 04:47 PM
  #6487
theisgroup's Avatar
there is not conversion kit, you just have to purchase the parts separately. and there are no part number for the bulkheads at this time. Xray said they will be available at some point
theisgroup is offline
Old 03-20-2004, 05:55 PM
  #6488
Okay sorry for the wording, has anyone put short arms on their XRAY and ran asphalt.
Old 03-20-2004, 07:06 PM
  #6489
JKA
I have. I run on an indoor asphalt track in Huntington WV. I see yout know Ycity pretty well... I would compare the Huntington track to Ycity... no carpet... add asphalt.. lol. Its pretty technical and tight just like Ycity.
The arms are great. I feel like the car is much more responsive with them. I've yet to run them on a large fast track like Parkersburg WV ( www.ovrccc.com )... but I'm guessing they'll be just fine there too.
I know a couple guys that run regularly at YCity. Guys from OVRCCC. I've run at the Y a time or two myself and you are right... one of the best track owners around.
JKA is offline
Old 03-20-2004, 07:36 PM
  #6490
just wondering but what is a good starting point for gearing should i use with an 8x2. Also, im using the stock pullies
Old 03-20-2004, 09:32 PM
  #6491
I have used the short arms on asphalt for a few weeks, it took some setup change to get it right. The biggest difference that I noticed was a mid-corner push with my existing long arm sertup. Once I got things worked out the car had tons of low speed steering and was super reactive. It also transitioned much quicker in chicanes.
barnacle is offline
Old 03-21-2004, 05:20 AM
  #6492
Scrad's Avatar
Trader Rating: 15 (100%+)
I know this has been asked before, but what are the part numbers to convert to the short arms? What else do I need besides the arms for my EVO and T1R. Also will the blade swaybar work on the short arms. Thanks.
Scrad is offline
Old 03-21-2004, 12:41 PM
  #6493
Scrad's Avatar
Also I thought that the Factory kit was going to have a stiffer chassis. It looks like it will be the same as the Evo2. I thought I saw one with only the 6 cells cut out.
Scrad is offline
Old 03-21-2004, 10:28 PM
  #6494
Is there any other place to get xray parts other than Mytsn?
10 bucks shipping regardless of what is purchased it highway robbery. What are they adding bricks to the package.
2000xp8 is offline
Old 03-21-2004, 10:51 PM
  #6495
JusBox's Avatar
do not buy directly from serpent usa. they are horrible to deal with.
JusBox is offline
