Like Tree3Likes
Xray T1
Old 03-31-2004, 01:08 PM
  #6631
forty6's Avatar
No, it doesn't.
forty6 is offline
Old 03-31-2004, 03:45 PM
  #6632
TRL
Post Short arms
I was just wondering if the short arms come in soft, med, and hard as well,anyone know off hand??
TRL is offline
Old 03-31-2004, 06:10 PM
  #6633
alana07's Avatar
Trader Rating: 53 (100%+)
Originally posted by Neosaka
With the factory kit, the chassis is the same of the evo2 freedom of choice? Or an new, the same of the official driver?
Yann.
the chassis is the same as the FOC, but with the stiff upper deck..
alana07 is offline
Old 03-31-2004, 06:12 PM
  #6634
alana07's Avatar
Originally posted by Pace72
i want to know if the new factory kit come with the spring steel hub for the wheel??
thanks
Pace
the FT kit comes with the new light weight alu hubs, not the spring steel units though..
alana07 is offline
Old 03-31-2004, 06:27 PM
  #6635
are you sure with the T1R Raycer chassis i can use the droop scew with the short arm in the back...one of my friend say no....but i want to be sure!
thanks
Pace
Pace72 is offline
Old 03-31-2004, 06:52 PM
  #6636
forty6's Avatar
Default Re: Short arm conversion
Originally posted by forty6
I'm trying to find the info on this thread but I can't seem to find it.
What parts does one need to convert a T1R to short arms? Is it as simple as replacing the arms and putting the mounts outside of the bulkhead? Thanks.
anyone
forty6 is offline
Old 03-31-2004, 07:02 PM
  #6637
forty6.. i don t think you need any special part to fit the new short arm...except the short arm itself.
Pace
Pace72 is offline
Old 03-31-2004, 07:15 PM
  #6638
Registered User
pace72 I am pretty sure you can use the droop screws in the rear.I don't really see why not, it's the same car but not graphite.
Zach P is offline
Old 03-31-2004, 07:19 PM
  #6639
Regional Moderator
BHenderson's Avatar
yes you can but you have to modify the T1R chassis for the rear arms. You have to dremel away some of the lip of the tub chassis in the rear for the arms to sit properly. Nothing too tough but this has to be done
BHenderson is offline
Old 03-31-2004, 07:32 PM
  #6640
thanks
Pace
After owning 3 xrays over the past few years, i think it is a complete joke that Xray did not include the Front spring steel hubs in the FT kit, the stock alloy ones start to bend in the first few weeks of running, and can damage both the bearing and the plastic part eventually.
I have seen some closeups of the new car and it looks very nice with all the refinements present, but a major let down IMO is the lack of SS Hubs.
Besercoe is offline
Old 03-31-2004, 07:33 PM
  #6641
Neil Rabara's Avatar
Just be careful when you dremel away material that you alter the tweak of the car.
Neil Rabara is offline
Old 04-01-2004, 06:35 AM
  #6642
sands's Avatar
Default Re: Re: Short arm conversion
anyone
Asside the short arms, you'll need to cut the aluminum suspension pin holder part in half. Both front and rear. Or you need to get the all plastic ones from the T1R. or you need to order the smaller, aluminum nut inserts from the Evo kit.
sands is offline
Old 04-01-2004, 11:10 AM
  #6643
sands's Avatar
Looking for a good, high speed outdoor, rubber tire setup for stock with short arms. Dug around on mytsn but didn't get pas the garbage.
Anybody have a good one?
Links?
thanks!
sands is offline
Old 04-01-2004, 11:24 AM
  #6644
forty6's Avatar
Default Re: Re: Re: Short arm conversion
Thanks for the info Sands.
forty6 is offline
Old 04-01-2004, 04:30 PM
  #6645
JDXray's Avatar
Default Pitures of Setups on Electronics
I need to see some pictures of other peoples setups on the electronics. I need to figure a nice and neat way to put all those wires around in my car. What i am saying is where the reciever,esc,servo wires go. In my T1R i have had it running for a bit now, but i still think there is a better way to put all those wires. If you know what i am talking about could you please show me some easy pictures of where to put these wires.
Thank you
Jon
JDXray is offline
