XERUN V2.0 Brushless ESC discussion thread.
#61
provided there is some ventilation to the esc, through the body it will be ok to use with stock wind motors and not use the fan.
But if you can make a plan to fit the esc without removing the fan then it would be better seeing electronics always run there best when kept cooler.
#62
EARUN 120Apm ESC
i have XERUN 120amp esc blue edition unit. I have a few question about it. THis ECS can run for both motor either is sensored or sensoless motor. As we know that hobbywing company was claim this esc can detect the sensored motor as sensoless if the sensored wire faulty.
How I want to know that im running in sonsered or sensoless system while sensor cable still connected to motor. Coz ..when im try to unplug the sensor cable from motor amd it still running and went im plugging the sensor cable the motor still running also.. then how i want to define that im running sensor or sensolless while the sensor wire still connected to motor.
Please advice... and on more ..think... when im conected sonsore wire to motor and make 1 trottle punch and green light was appear blinking non stop.... but motor still running good. but when i unplug sensor wire ... the green light only appear when i pull the trigger only...
Hope u all can help me about this..
#63
when the esc is used sensorless it is only when you move from a standing position that is affected.
Sometimes it will hesitate a bit as you accelerate other than that it will run great.
#65
If you set 'AMTS' anything other than '0', the motor will rev higher in sensored mode. Listen to the revs with 4 wheels off the ground.
#66
The esc uses the sensor to help the car accellerate from a standstill.
Once the car is moving the esc switches to sensoreless.
With out the sensor lead connected and if you tried it you would notice the car stutter or hesitate (commonly called cogging) a bit when you accellerate from a stand still and in some cases it sometimes stutters badly and can even go backwards before going forward.
#67
#69
#70
Being new to the whole brushless thing i thought i would share what i found in the hope that it might help someone or someone could help me.
still basicly have the speedy set to default settings except for the lipo cutoff.
Last week i got around to giving the car a bit of a run with other cars,
I managed to get a couple of ok runs in, with the playing i had i changed the FDR from about 4.9 down to 4.1. at the end of the race (4min) the motor came off at about 36c so i dont think the temp is an issue.
Seems like at around the 4.9 mark the top end was slow compared to other cars. with some local advice i changing to 4.1, This helped the top end and shaved .5sec off my best lap for the night.
at 4.1 i ran out of pinions, so im changing the spur to allow me to get to about a 3.8. should give me a good range to play with 5.2ish to 3.8ish.
the motor seems smoother now after a bit of a run. my car needs some serious work in its setup so at the moment the speedy /motor isnt whats slowing me down.
it looks like the older fixed timing motor that comes with the speedy combo is outclassed these days but it will do me for now.
hopefully i will get another run tomorrow.
Hopefully the LCD programmer will turn up tomorrow. it was ordered about 2 weeks ago but still isnt here.
#71
OK, the usb programming card turned up overnight.
can someone tell me what the different firmwares do or which is the one to get for stock?
looking at the SP thread the 312 is designed for stock but i couldnt find anything in the hobbywing software to say that.
Also what sort of max temp should i be trying to stay under with the motor?
Peter
Peter
#72
Seems like Hobby Wing has a new look for their 1/8th systems.
Very nice.
Very nice.
#73
What profile is recommended for stock motor?
#74
I use a motor with Novak 17.5 Ballistic software V1.10_090323a_t on track with straights of about 50m with good results.
Now I have installed the software V1.10_090323a_m and I could not even prove that there are differences between the two software?
Or possibly what software is best used with the 17.5?
#75
