XERUN V2.0 Brushless ESC discussion thread.
#406
My mate has tested this 231 firmware on his XeRun120 side by side with my Tekin RS Pro firmware 203.Both of us are using SP11.5T motor, FDR 7.99, same car TRF416X and same tyres. On a very long straight I say the top speed is almost the same as my Tekin. How ever my Tekin has more rips out of corner. When I drive his car I felt it was a bit soft in punch and the supercharger would only come in about 2/3 of the straight distance. Our motor temp was about the same at around 67-70ish deg C. this was only for initial test, I m sure this can be improve with a bit of fine tuning the esc set up. Overall I m impress with the new firmware. I just wish that the HW guys gave this firmware during recent TITC that I attended, at that time they only gave us firmware 229 eventhough we saw this 230 and 231 firmware on his PC.
#407
Well, it was already set at 4000rpm with delay of 0.2. I know this coz I set it up for him. Maybe tomorrow we test it with different gearing or timing. If you guys has any good setting pls post it here.
#408
Hi cherry, what version does the LCD programmer have to be in before it can update SP software ?
#409
#410
Cherry how many settings do you have on menu #15? I have only 6.
#411
#412
Tomorrow is the big day, have just dropped my best motor OUT of the car and put in a spare Novak 10.5 with a 13mm Rotor, as didn't want to blow my Fantom motor. Revving it up on the bench it sounds like a dentists drill and the turbo kicks in really well and you can hear when you adjust the revs at which it comes in, have mine set to 10k RPM but may need to drop that on the track, all other settings are at minimum except AMTS which is at the stock 11.25. Will update on the condition of my motor on Friday, kinda expecting it to blow though.
Hope you find the right set-up, for me it is also importend to drive a motor
with 12.3 rotor because it is stock spec for us together with 13.5 t.
Hope you find this as well.
Happy testing Cherry
Ed
#413
Just checked 6 only mate.
#415
Apparently so, I would expect the upcoming 'new' speed passion LCD Programmer to come with the new paramenters installed, but seeing as this is only beta software they used the LED card instead. The hobbywing LED card is cheap off of fleabay anyway so......... As a precaution though I wouldn't run this software without having an LED card unless you are running 13.5 or higher because the default settings on the software are set for 13.5 and will in all likelihood blow up anything hotter wound.
#416
Okie dokie I did I updated the speedie with the new firmware. I have a problem however, I'm not able to recalibrate the speedie to hit the green light at the top of throttle.
Could it be i'm doing something wrong or the firmware not liking the radio. I'm using a ex-10. I've tried adjusting the TH: Hi-point all the way up to 150 with still no green light
Cherry you have the answer for most could you please me once again?
#417
Ok, I'm not sure exactly what difference it made, plugging in the motor got me a green light.
I did something I know I shouldn't have and free revved the motor to full beens to see what would happen. I must say it had quite the rip. I am so looking forward to the weekend.
Anyone got some gearing suggestion for a 17.5?
By all reports if it has similar characteristics to the tekin then I'll be starting around the 8.5 mark. Any thoughts?
#418
Try calibrate it with throtle and brakes on EPA 100 and after calibration set the EPA on 110 on both.Maybe it works like this
#419
I haven't run it on track yet.After Sunday race i'll know if i'll go on with this esc and software or i'll move to the Mamba Max Pro.
#420
When I try to update the LCD card after downloading the super charger files , replace and rename the two files. It would let me update, it said it cannot be update to older version. How do I reverse the LCS sofeware??
