-   -   TC3 Forum (https://www.rctech.net/forum/electric-road/29-tc3-forum.html)
Bubblestc3 11-05-2003 04:37 PM
Re: shaft
Originally posted by tc3rookie
i'm running the woven shaft again and am wondering what shaft the yokomo is, pt. #? is it a direct fit? thanx
tc3rookie,
The Yokomo shaft is a direct replacement. I myself was amazed!!!! As for part number, I do not know it at the time, but I will try to find it for you.
Intermision 11-05-2003 04:44 PM
What would the Yokomo shaft do different?
Bubblestc3 11-05-2003 04:47 PM
The slop in your servo is somewhat similar to your gear mesh with the motor. Too tight, and the servo will bind, too loose, and the servo will strip gears. As metal gears in a servo wear, there becomes more and more slop.
Another thing to consider is what servo horn you are using, which you are using an aluminium horn, and check the slop in that. The servo mounts are another thing to consider with slop that apperently comes from the servo, and how tight they are on the servo.
Bubblestc3 11-05-2003 04:49 PM
The bones of the shaft are aluminum(that connect into the drive cups), and the accual shaft is carbon.
mistercrash 11-05-2003 04:52 PM
when you made that brace for the center, what thickness of CF would be good?
2 mm :nod:
tc3 racer sc 11-05-2003 11:16 PM
thxs mike d
hey thxs for setup mike d i race with u at durham i cya in clevland
sars125 11-06-2003 12:19 AM
Re: setup info
Tanhx it's this a site wich can help me a lot
Greetz lars from holland
tc3rookie 11-06-2003 11:58 AM
slop
the servo arm is not very old and i had this same problem with another arm. i'll check the slop in the gears. if there is, would a new gear set fix it?
Bubblestc3 11-06-2003 04:03 PM
It depends on the ammount of slop that it has right now. If there is a little, then new gears will not help it(it should be the same), but if there is a bunch of slop, then new gears will fix most of the slop.
Flash Gordan 11-06-2003 07:06 PM
I know I should search this out on my own but does anybody have a list of modifications that have been discussed in all the pages of this thread?
mb racer 11-06-2003 09:21 PM
Re: slop
:D just remember to replace the ball caps and ball studs too ,, this should help alot .. even with a worn servo,, you may still have alittle slop but you cant just change one thing ,, sometimes its ok. but its better to change it all then youll have a better out come.. my 2cents...goood luck ..:D :tire: :tire: :tire:
tc3rookie 11-07-2003 11:10 AM
servo arm
it turns out the ridges in the arm and on the servo didn't match very well, so i replaced the alluminum one with a plastic and it works really well now, almost no slop. the rack isn't as free as i'd like but i fixed it a little and now it's a lot more free than be4.
Bubblestc3 11-07-2003 03:35 PM
The major things that have been discused in the past have been:
Rear shock tower up front, chassis refinements, Nitro steering system, drivetrain, spool's, and one-ways.
But then again, I have only been on rctech for two or three months...
berger 11-07-2003 04:16 PM
I have my own mod, for my rpm bumper, the middle two holes which the diff sits through i cut slits in so that i can just undo the two screws holding the front arm mount on and pull the bumper off, saving undoing the diff, this way if you break a front wishbone its really easy to change it fast. Also i just sand my hinge pins down a little bit until they are steel coloured and not black, allows the wishbones to drop freely.:nod:
berger 11-07-2003 04:17 PM
If i can be bothered ill take a picture of my bumper tomorrow.
