-   -   TC3 Forum (https://www.rctech.net/forum/electric-road/29-tc3-forum.html)
speedxl 11-08-2003 05:03 PM
irs axle stink just scrape the wall and there it goes there is no
advantage to using them and as far as the spools
i seen guys that can make the a main at a national and disentergrate a spool . these parts are just as prone to breakage then the factory parts the irs axles are diffinatly a cheaper buy!:D
trackdesigner71 11-08-2003 05:09 PM
Any of yall have experience gearing an Orion Core Stock for the TC3? Advice would be most appreciated
Bubblestc3 11-08-2003 07:33 PM
td71,
When the KO GP was at SoCal in June, I raced with a 6.94 overall(a core based handout motor), which was 36/100 in 64pitch gears.
tc3 racer sc 11-08-2003 07:35 PM
who got the best ceramic bearings for tc3
where can i fine the best ceramic bearings any website or hobbystore have thm please post
Bubblestc3 11-08-2003 07:49 PM
You should check out acerracing.com , they have cerimic berring kits for the TC3.
Trinity should also have some cerimic berring kits for the TC3
Super Steve 11-08-2003 09:50 PM
My friend smoked his Monster stock with stock spur (72 48pich and 26 48pitch pinion)
The manual reccomends 28 so 26 should be safe i would think?
Was it because his motor had a defect?
O well... at least I TQed and took first... :D
nitromike 11-08-2003 10:04 PM
That's not too high. I gear mine 75/28, which is 6.69 GR, 72/26 would be 6.92. That is just about right from what the guys around here are running.
Super Steve 11-08-2003 11:03 PM
1 Attachment(s)
some pics of the armature
Super Steve 11-08-2003 11:08 PM
1 Attachment(s)
Pic 2
Super Steve 11-08-2003 11:10 PM
1 Attachment(s)
lastpic
Speedie 11-08-2003 11:51 PM
that got hot
I use an infared heat gun to tell if my gearing is ok for the motor. In my opinion ya can just gear it till it melts. A few times what felt good on the track seemed a little warm when I was done I dont like to get my motors over 150f or so. I know Ive seen on forums that others run em alot hotter but for what I do reliability is more important. thats just what my little experience has taught me.
lee82gx 11-09-2003 12:36 AM
might be the drive train is binding.too much load will cause shorting/smoking/frying,as the current can't be converted into motion,thus it converts to heat.
i've geared my stockers(27T) up to mid 5's and 23T stockers into high 5's,no problem as long as there was sufficient cooling between packs.
lem2 11-09-2003 12:41 AM
Re: Re: QUestion
Originally posted by Flash Gordan
I know Dave Irrgang personally and know everything he makes can take one hell of a beating. His stuff is almost damn near indistructible. How did you ruin 2 spools?
Yes I agree, I use a lot of IRS products and Love them!! Call it stupidity that's why I ruined them, hehehhe I ran out of Pin Cushions, thats how. No place to buy IRS Pin Cushion here. Just order, I have around a dozen already just waiting for my cuz to come here and visit.
But I broke one when I clip a corner, when the arms broke,one of the wing on the outdrive gave way.
Incidentally I use, IRS Side Braces, Drive cups, spur gear holder, trans. holder and so many more-- all from IRS!
Peace and Happy Racing!!
berger 11-09-2003 05:51 AM
Ive run my monster geared low and high and it seems okay, ive been going pretty fast with it so far.
Flash Gordan 11-09-2003 06:50 AM
Hey lem2 you do know you can order everything straight from the IRS website. The address is:
http://www.teamirsrc.com
Probably will get your equipment faster that way.
