Move Battery To Center
Can somebody please tell me how much to cut the chassis to move the
battery to the center |
well, i forgot exactly how much i took off, keep going till your batts almost touch the shaft
I cut half out of the mid brace and move it over. The batteries will rub the shaft without any battery bars on the batteries..With Battery Bars the shaft is about 1.5-2mm from the shaft
my batteries are about 1/8 of an inch away from the driveshaft in front position and about .030 of an inch away from outdrive in the rear position.this is the way my chassis comes cut.the battery slots are also moved a little bit forward so under certain track condition,the rear can be utilized.i personaly run them in front position.rear felt good i just like having a little extra front bite
you can go to bmiracing.com for some pics at different angles
tir screws
TiR titanium screw kit! pretty expensive, but all use 2.5 mm (or something.) lighter than stainless, stronger than alluminum.
Originally posted by SpeediePHATT Mister crash This is the place ya want to look this guy took all the guess work out of doing alot of the mods ppl do the tc3. He put alot of work into his site. |
Has anyone else tried the tobee craft hardened steel cvd bones from speedtechrc? I have had great experiences with them so far; they seemingly have no wear and are very light considering they are steel. Not to mention they are only 11 bucks.
what is the part # for the steel cvd
Originally posted by ae4ever what is the part # for the steel cvd http://64.70.208.72/speedtechrc/185.html |
Re: Need help to measure toe in/out!!!
Originally posted by TAC3 I have a eagle racing gauge to measure the front toe in/out , but i am just wondering, do u guys measure the front toe in/out while the radio is on or the radio has to be off when measuring the toe? because one of my friends told me that I should turn the radio on when measuring my toe, but everytime I move the steering the degree changes (cause me a headache), any tips for me? Thanks guys, apreciate ur help To horatio , thanks for the essay :) So - you want your steering centered to measure toe-in. I don't turn on my radio (bad habit at the track and it's not always centered. . .). With my TC3, I look underneath - there's a little hole that is centered underneath and just slightly behind the steering rack - if you look through it, you can see the screwhead that goes through the cam portion of the rack. When you can stick a 1/16th (I think) driver into that screwhead via that hole, you're centered! No radio, centered. . . Now, for a shortcut to that - take an Xacto knife and scrape the top edges of your steering rack on either side of the driveshaft (once you've gotten it centered) - now you have a view from above. . . |
Re: Move Battery To Center
Originally posted by flbugboy Can somebody please tell me how much to cut the chassis to move the battery to the center |
great tip boomer
Heat Sink
Hi,
This may or may not have been asked before, but here goes. Ok, I understand that the radial heat sink (that clips directly on the motor) would actually increase heat because it blocks the vents, so I dont plan to use that. I have the Team kit, and it has the standard small black heatsink attached on the motor mount, would the FT motor mount (the larger blue one) provide better cooling, or is it even noticeable ? |
| All times are GMT -7. It is currently 06:12 PM. |
