-   -   TC3 Forum (https://www.rctech.net/forum/electric-road/29-tc3-forum.html)
mike_Webb 03-10-2003 09:24 PM
Nitro is a different beast then the Electric. Plus a lot of dirt and fuel.
AssociatedRacer 03-10-2003 09:29 PM
What exactly does the Ntc3 steering mod do?
Hooked 03-11-2003 12:12 AM
Replaces a steering system prone to dirt and grit causing steering problems with a steering system that does not have that problem ...
But ...
It also weakens the chassis to the point that an upper deck and side braces are almost a must have ...
also ...
You have to be absolutely accurate with your measurements when drilling holes or your steering geometry will be off.
Dingus 03-11-2003 06:05 AM
I haven't done it yet, but I think the NTC3 rack adds Ackerman and/throw and requires less maintenance.
I have milled the chassis and that makes a huge difference in weight transfer speed. I think the chassis was more balance when it first came out years ago because the batteries were lighter than the current 3300's.
Ken,
Don't know anything about the IRS setup, but there are people here who drive them. Maybe check with RC-Zombies (he's posted recently, pm him).
d
IMPACTPLAYR 03-11-2003 08:01 AM
Yeah, batts keep getting heavier and electronics keep getting lighter!!!
OB42TC3 03-11-2003 08:17 AM
The ntc3 rack adds ackerman, too much with the stock steering hubs, however if you used it with NTC3 front suspension it works pretty well.
DOTMAN 03-11-2003 09:02 AM
Does anyone know someone out there selling milled chassis' or know someone I can send my chassis to to have it milled. I'd like to try the batteries moved in closer to the shaft but I don't have the equipment to make the mod myself.
theisgroup 03-11-2003 09:05 AM
milled chassis
i believe that rayhuang is doing them.
mike_Webb 03-11-2003 09:06 AM
DOTMAN... I have the tools to do it now... I jsut got my Drill Press last night. Shoot me a e-mail. [email protected]. We can discuss it and I can send you a picture of the chassis I did last night.
clone 03-12-2003 06:29 AM
TTT
Jon Kerr 03-12-2003 06:42 AM
Anyone have any idea on who actually sells the Losi Alpha body on the net? I can't find it anywhere.
AssociatedRacer 03-12-2003 07:03 AM
http://www.kthobbies.com/store/sedan_bodies.htm
Dingus 03-12-2003 07:51 AM
Outof stock at KT,
try
https://www.ssl-stormerhobbies.com/c....pl?pn=LOS8053
I think they ship from CA.
rc-zombies 03-12-2003 08:06 AM
Originally posted by Dingus
Outof stock at KT,
try
Stormer is in Montana.
AssociatedRacer 03-12-2003 08:18 PM
Hey guys, when I see a lot of the pro's cars, instead of using the foam to space out the battery, they use a seperate battery cell. Is there any balance reasoning to it? Isnt the battery side already heavier?
