The Speed Passion Thread >
Like Tree57Likes
Old 07-07-2010 | 01:03 AM
  #4831
mlight13's Avatar
What's the best STOCK software prior to the new supercharger stuff? I am now using 100110_STOCK. Is this best for small/medium asphalt tracks with a 17.5 or should I be using a different version? I will be using it for RCGT which the rules state "Any ESC/firmware without boost". Thank you...
mlight13 is offline
Old 07-07-2010 | 02:12 AM
  #4832
cherry2blost's Avatar
110 with max timing on the ESC and mechanical timing on the ESC geared in the 7's always worked well for me, course you could run the latest firmware with Turbo level on 1 (OFF) lol.
cherry2blost is offline
Old 07-07-2010 | 06:10 AM
  #4833
skypilot's Avatar
Originally Posted by shesha
My question in regards to the LPF an the GT if they are the same in size how can one handle a higher performing motor ?
I heard some info the other day that some drivers are using the LPF with less then the 5.5 turn and not having any issues ?
Anyone care to enlighten me on this ?
my car is the same size as warren johnsons but his does the 1/4 mile in under six seconds and over 200MPH, mine doesn't, should I open mine up and compare the internals?
skypilot is online now
Old 07-07-2010 | 03:42 PM
  #4834
So is anyone running 1s lipo yet? You guys using boosters or receiver packs?
Tha Skinny is offline
Old 07-07-2010 | 04:13 PM
  #4835
mr crum's Avatar
im using receiver pack with the speed power 5500 45c
mr crum is offline
Old 07-07-2010 | 04:22 PM
  #4836
LMRacing's Avatar
The LPF is a little bit lighter and is more prone to heating up, running higher turn motors means more heat, enough heat means melting the solder inside the speed controller which also means a dead speedo.
Its like using thinner guage wire, you save weight but you generate more heat so you use the smallest you can safely get away with to save the weight without melting things down. Some people use the LPF to save weight (and some money) because they know there not going to run that low a turn of motor.
Honestly I wouldn't use a speedo like the GT2.0 or a Tekin RS to run a mod motor with anyway. I find older speed controllers will acctualy turn a mod motor faster than the newer speedo's with the boost capability, there also cheaper to get your hands on.
The best Mod Speed controller i ever had was one of the original Speed Passion Fiego Brushless/Brushed speedos. I sold it to a local for $30 because he wanted to go from a brushed setup to brushless as cheaply as possible and I wasn't running mod anymore
LMRacing is offline
Old 07-07-2010 | 05:03 PM
  #4837
hairymuffin's Avatar
Has anyone sent in a esc for repair with good results?
hairymuffin is offline
Old 07-07-2010 | 05:37 PM
  #4838
Guys. I have a big offroad race this weekend and am not sure if I will run 13.5 super stock or mod class with a 9.5. Has anyone found a way to run 528 with a mod and figured out a way to turn the Supercharger settings off? I won't be able take my laptop so...
If I turn SC boost to OFF and SC full throttle to OFF...will this do it? I would like to be able to show up with just 528 installed.
kwiksi is offline
Old 07-07-2010 | 08:23 PM
  #4839
mr crum's Avatar
there is a 528 mod aswell as stock i ran a b44 with a 10.5 with one of the first sc softwares everyone else was runnin 6.5 i was alittle under powered compared to them but with 528 it might be the way to go
mr crum is offline
Old 07-07-2010 | 09:16 PM
  #4840
Rdog's Avatar
Well I run on road but I can a 9.5 in the mod class I was just a tick slower on the strait but on the in field I think its just a fast. I think some of my lack of speed on the straigh was me not having the right FDR but I really like the 528sc software really make its nice not having to run a 4.5 thats just a bit to much for me to handle
Rdog is offline
Old 07-08-2010 | 09:34 AM
  #4841
altreyx's Avatar
Arrow Speedpassion Setup Sheet ver.528
Hello guys with the final firmware release i have updated the Speedpassion Esc Setup Sheet
For the best view use Acrobat Reader 9.x i'm not sure how it can work with another program.
Hoping you will like it,
Regards
Andrea
File Type: pdf
altreyx is offline
Old 07-08-2010 | 09:41 AM
  #4842
corallyman's Avatar
What length is the shortest sensor harness that SP offers? What is the shortest length that anyone offers? I am looking for a short, flexable TC setup, the shorter the better.
Thanks,
Steve
corallyman is offline
Old 07-08-2010 | 09:44 AM
  #4843
charlie_b's Avatar
Super Moderator
Regards
Andrea
Thankyou Andrea for all your efforts!
charlie_b is offline
Old 07-08-2010 | 04:07 PM
  #4844
iPearl's Avatar
Anyone know if i can run 3cell Lipo with the Speed Passion 2.0 GT LPF ?
on a 10t VXL Traxxas 540 Motor, in a 4wd SC ?
iPearl is offline
Old 07-08-2010 | 04:17 PM
  #4845
Thanks,
Steve
90mm.
Danny-b23 is offline
