The Speed Passion Thread >
Like Tree57Likes
Old 01-05-2010 | 10:21 PM
  #1621
Stein Tumert's Avatar
Originally Posted by Robio
Can someone can walk me through the v132 download process. I have v131 on the lap top. Would like to try the 1110 software with my 13.5.
Thanks, Rob........
You need to uninstall the 1.31 version from your laptop, then go to the SpeedPassion home page.
http://www.speedpassion.net/en/productDetails.asp?p=65
If the link does not take you there, go to "optional parts" and then "LCD Program Card". When you are there click on the tab "downloads"
Now you can download 1.32 and install it. (you might want to download 1.31 and not install it, just to have it for later in case)
You also need the LCD programmer to change firmware versions on the ESC.
Stein Tumert is offline
Old 01-05-2010 | 10:55 PM
  #1622
veecee's Avatar
Originally Posted by TryHard
Ended up on 5.94, and think that maybe about right with the V3 motor, as I know they run cooler than the V2 I had in the car. Or too put it another way, it's where I'll be starting this weekend, now I have a new sensor board
HiH
Ed
Thx Ed. Looking forward to trying 107 in the "X" this wkend!
veecee is offline
Old 01-06-2010 | 07:21 AM
  #1623
Drillit's Avatar
From: Oreganastan Pacific Wonderland home to Indoor Farming
Got a Stock (17.5) 12th 1s race coming up.....(yah so what....I'm the only one) for past events I found the 312 IS/WAS the only program that would run it. Now that I have been lured into deleting the 1.31 file to load the 1.32 file, I found that 1.31 no longer contains either the 312 or 323, just 205 and below. with the 1.32 only supporting the 323, I AM royally Screwed.
I also found that I can load both 1.31 and 1.32 to my computer, they came up as seperate files/icons. Pick one and plug it in and use it.
I realize that Speed Passion's site is where these programs are downloaded from, not from Florida.........while YOU guys are down there testing fets for the Team Members, is there any way a B-Main guy like me can get the 312 program?
Thanks for your concern.
Mark
Drillit is offline
Old 01-06-2010 | 07:46 AM
  #1624
TryHard's Avatar
Mark
Hi Mark,
Drop me a PM with your email address, I'll send over a copy of the V1.31 software I have on my comp that I know contains the 312 software. Otherwise, Adam posted to a copy of the v1.31 in this post back on page 84.
http://www.rctech.net/forum/6687568-post1246.html
(edit - on second thoughts, this is the exact software I have anyway, as it's where I d/loaded it from originally )
HiH
Ed
TryHard is offline
Old 01-06-2010 | 02:48 PM
  #1625
Drillit's Avatar
Ed, Thank You
Drillit is offline
Old 01-06-2010 | 03:52 PM
  #1626
Mark, Could you post your set up info for 17.5 1S once you get it sorted out, or at least a good starting point for roll out with the 312 software.
Thanks,
Tim
got2bqik is offline
Old 01-06-2010 | 04:32 PM
  #1627
mr crum's Avatar
Originally Posted by saleen95
Hello every body . Just bought me the new 2.0 lpf, the blue edition. Bought it about a week ago. Was wondering if any body new what program came with it from factory. Running 13.5, want to make sure I have the right one on my speedo before I run car thanks
the stock software that comes on the speedo is 205g
mr crum is offline
Old 01-06-2010 | 05:15 PM
  #1628
Hey. I got my 17.5 V.3 motor in the mail today Just wondering how to do the wires. Never had to solder a motor before, much less a Speed Passion. I know the V.3 motors have the clip on wire clips or whatever, and i thought i was supposed to get new wires with the motor.what should i do? Do i need to just solder them by putting the wired in the little opening??? I'm kinda confused. Please help me and my stupid questions
Dan
TC4Racer123 is offline
Old 01-06-2010 | 09:45 PM
  #1629
The Hawaiian's Avatar
Dan
if u don't figure it out I'll help u Sunday...
has anyone tried the new software yet?? Adam says it should be up to par with the other "fast" speedo out there
I hope to try it in 17.5 Sunday @ Adrenaline raceway
The Hawaiian is offline
Old 01-06-2010 | 10:44 PM
  #1630
[QUOTE=Stein Tumert;6813240]You need to uninstall the 1.31 version from your laptop, then go to the SpeedPassion home page.
Stein thank you,
I do have the programmer, just not the instructions as it's borrowed until mine arrives.
Yes I would like to keep 1.31 also. I did'nt know I could keep both.
I'll see if I can figure it out.
Thanks again, Rob..........
Robio is offline
Old 01-06-2010 | 11:17 PM
  #1631
danjoy25's Avatar
Thanks,
Tim
+1 as well Mark.
I was going to run 12scale using 1s lipo and would like to know if you run a booster, receiver pack or non at all and also if you set the lipo voltage cutoff to #1.
danjoy25 is offline
Old 01-06-2010 | 11:19 PM
  #1632
dpatterson26's Avatar
What gearing should I use with the new profile?
dpatterson26 is offline
Old 01-06-2010 | 11:22 PM
  #1633
kschu's Avatar
i heard SP develop a new software that can make d stock motor running fast....should be releasing soon...
kschu is offline
Old 01-06-2010 | 11:28 PM
  #1634
Thought that was the other guys that did that?
Old 01-06-2010 | 11:54 PM
  #1635
Drillit's Avatar
Thanks,
Tim
Hi Tim, I run indoor low to really good traction carpet. For 1s 17.5 I run 312 at 89-92mm have had it as high as 98, all it did was slow down a little and got up to 130-140f temps.
programmer set-up: 2.0 (LCD)
1 RM forward only
2 DBF 3-4 (10-20%)or to your liking if you use some
3 LV 1 none
4 DRRS 9 (IX)
5 BF 4 (100%)
6 RF 4 (100%) Adam mentioned max on these many pages back in the thread
7 IBF 1 (drag brake force)
8 NR 2 (9%)
9 "ATMS" timing 8 (26.25*)
10 O-Heat Protection 1 (enable)
car set-up = can-O-worms? 12th Scale thread and your chassis threads ASC, CRC, Speed Merchant etc.
Tires- what are the locals using?
chassis? you know the old t-bar vs. link routine.
pics of my 12L4 are in the 12th 1s wiring thread, it's a little different
Good Luck laying down the foam
Mark
Drillit is offline
