"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors >
Old 10-29-2011, 02:15 PM
  #1741
cheehtae's Avatar
Trader Rating: 15 (100%+)
don't hit the wall too much
cheehtae is offline
Old 10-29-2011, 02:34 PM
  #1742
Mugen10's Avatar
spoken from a true wall hugger.
Hey I only hit the wall that one time.
Mugen10 is offline
Old 10-29-2011, 03:42 PM
  #1743
Originally Posted by TryHard
Nothing.... The split blocks are the same height as the standard blocks the right way up. If you've been running a 3mm shim under the front rear block, then no shims under the split. 3.5mm, then 0.5mm under the split blocks.
HiH
Ed
What about the rear split blocks? If a 0.5 mm shim is currently being used underneath the XA block, then do the split blocks require shimming?
thx!!
mhavlena is offline
Old 10-29-2011, 10:13 PM
  #1744
sonic31's Avatar
Trader Rating: 6 (88%+)
Originally Posted by Mugen10
Help needed from anyone.
My 416x has a issue on a tight carpet track. The dogbone pins are coming out of the wheel axle and sometimes bend. The dogbones are stock and the outdrives are stock. Is there a stronger or better dogbone? I am using loc tight on the grub screw. They are only doing this in the front.
(Just for more info. the pin that is coming out of the dogbone is just behind the wheel).
Also what do you recommend for spool outdrives?
Thanks for the help
use the tamiya 46mm dogbones in the front, that should help. also try cleaning the whole universals up then rebuild them with the loctite. after you're done put a piece of shrink tube on the axle to help keep the pin in place.
sonic31 is offline
Old 10-30-2011, 09:32 AM
  #1745
TryHard's Avatar
thx!!
Yes, they would require shimming. Just treat them the same as a one-piece block mounted the normal way up.
HiH
Ed
TryHard is offline
Old 10-30-2011, 09:45 AM
  #1746
TryHard's Avatar
Thanks for the help
To stop the pin coming out, you could switch to the 417 axles, that use the spring clip rather than grub screw.
Dogbone wise, use the steel versions in the front (TAM51092 for 46mm, TAM54078 for 44mm) to stop the bending... this last for ages, I have never broken one!
Spool outdrives, my current preference is for the Roche Spring steel... running mod, I've had them on the car for 2months+ now, and still not a scratch on them, top marks from me. I've even had to replace the driveshafts because the pins have worn more than the outdrives!
HiH
Ed
TryHard is offline
Old 10-30-2011, 09:55 AM
  #1747
TryHard's Avatar
Hi Jilles,
Have you got any suggestions for the 417 on carpet? I've never actually run mine on the rug... and the last time I ran on carpet was almost two years ago now!
Trying to get sorted out for the ATS at Yatabe, not going to have much opportunity to practise, so would like to hit the ground running!
I see Marc, Viktor and Elliott are all running the X at the ETS, including the flexy bits... you think this is the way to go?
I know my 7 feels really good on high traction with it flexied up, so I'm thinking to start out there, and go with White/Blue springs and 500wt... just a little confused where to try the wheelbase and rear block (pic I saw of Viktors car looks like 4mm in front of the rear arm).
Are you going to be coming out to Yatabe for the ATS? or does it clash with the Ride cup?
Thanks in advance
Ed
TryHard is offline
Old 10-31-2011, 12:24 PM
  #1748
CHICO1977's Avatar
HiH
Ed
Hi u had to replace the drive shaft r they Alu or Steel?
CHICO1977 is offline
Old 10-31-2011, 06:36 PM
  #1749
TryHard's Avatar
I have always used the steel fronts... until this past weekend where I thought I would try the alloy ones, and promptly broke my first one!
HiH
Ed
TryHard is offline
Old 11-01-2011, 03:52 AM
  #1750
In my first race ever with the 417 (coming from an Xray) with the alloys up front, I bend one of the driveshafts. No serious hard hits. So steel up front!
Nilks is offline
Old 11-03-2011, 07:29 AM
  #1751
Swampracer's Avatar
Trader Rating: 72 (99%+)
Default Pit towel question
Thank you Jilles for releasing your new 3 part video series on the 417. It is very helpful.
I have a question? Is Tamiya planning on releasing the pit towel and pit board you are using in the videos?
If so, where can I find them.
Best regards,
Greg Gherasim
Squamish, B.C. Canada
Swampracer is offline
Old 11-03-2011, 07:56 AM
  #1752
artwork's Avatar
Trader Rating: 88 (100%+)
I wont speak for Jilles, but if you have a tendency to hit stuff on the track then the best option would be to run Steel up front. I run steel in the front and aluminum in the rear. Not to many drivers I know could get a way with running the aluminum CVDs in the front they are simply too soft.
artwork is offline
Old 11-03-2011, 08:25 AM
  #1753
kedal's Avatar
Do you think there is a difference running the steel shaft on the rear insteed of the alloy ones ? I run steel on the rear for now.
kedal is offline
Old 11-03-2011, 09:34 AM
  #1754
any chance of tamiya releasing their own DCJ for the 417?
Minami is offline
Old 11-03-2011, 03:23 PM
  #1755
Best regards,
Greg Gherasim
Greg,
Towels and setup boards like those were sent exclusively to japanese supporters of the TRF project along with a respective member card (project supporter member's card). Supposedly, they are only available in Japan (and also for TRF team drivers, of course) but you might get lucky on Ebay???
Good luck!
Cheers,
José Cordeiro is offline
