T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 04-18-2011, 01:48 AM
  #7411
Originally Posted by Luppi Stefano
I tried u-pro spool...
delrin cup, after only ONE race, have a little break...
there are steel cup, compatible with u-pro spool?
RC Market have got steel out drive cups for the u pro spool
mcb-jet is offline
Old 04-18-2011, 02:02 AM
  #7412
smilekt's Avatar
any one using Lightweight Gear Diff ? any good difference
Attached Thumbnails T.O.P. Racing "Photon" 1/10 EP Touring Car-mp-tp-0001.jpg
smilekt is offline
Old 04-18-2011, 03:53 AM
  #7413
vr01's Avatar
Depends on how you like your car and what the track conditions are like...
I found that it dramatically changed the balance of the car but the track I run on is very low grip. For me it gave too much rear drive to the car.
vr01 is offline
Old 04-18-2011, 03:54 AM
  #7414
vr01's Avatar
Originally Posted by Professor
phil
matty stambulos has been using it along with brad verco in mod for the last 2-3 weeks & had no isseus with it to date the added flex is actually quite good
graham
It seems I have been away for too long What is this modification of which you speak???
vr01 is offline
Old 04-18-2011, 10:20 AM
  #7415
I think that you will get some better diffs if you buy the Yokomo or Spec-R diff. I have broken 3 or 4 of the small diffs , but after I bought one of each , I havnt broken one since. Use them both in front and rear
johnsen-dk is offline
Old 04-18-2011, 10:26 AM
  #7416
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Originally Posted by OVA
So what set up is everyone is using for outdoor med traction grip?
I posted one if Larry's from last year at http://racerlog.com/wiki/T.O.P._Photon#Setups . Look for the one from Jackson.
I haven't run outdoors yet but I'm going to mix that setup along with my current carpet setup.
Originally Posted by TeamWTF
Is the single screw layshaft modification ok to use with modified?
I want to try it but I cant help thinking it would flex a lot (Possibly causing gear mesh problems) ???
Yes - single screw is good for mod. We are running the lunsford titanium fatboys.
hanulec is offline
Old 04-18-2011, 10:29 AM
  #7417
hanulec's Avatar
+1
hanulec is offline
Old 04-18-2011, 11:26 AM
  #7418
Originally Posted by John St.Amant
The #ed blocks 9,10,11,12, make more difference than the numbers show. In feel anyways. I would have liked to see the #'s further on in deflection. Like 30, 35.... 45 would have been the upper limit I think.
I'm running 4mm of spacer and a one way .. the spool is just too tough on the parts inventory. I will have to measure the total length from center pivot to center line of the pivot ball. (416)
sorry to dig up an old thread , does no.9 insert give the most steering coming out of a corner ?? ..
shaun207 is offline
Old 04-18-2011, 12:35 PM
  #7419
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
no #10 does more
OVA is offline
Old 04-18-2011, 04:45 PM
  #7420
I have been thinking about this relationship, i wonder if it would be beneficial to run a 1 tooth smaller front pulley to compensate for the additional rear drive? I think this is referred to as overdrive
Get the front of the car dragging itself out of corners a little more?
Besercoe is offline
Old 04-19-2011, 12:11 AM
  #7421
no #10 does more
ok cheers , i just thought it would make the inside tire turn sharper ..
shaun207 is offline
Old 04-19-2011, 05:53 AM
  #7422
vr01's Avatar
Yeah that's called overdrive. It might help but it will also cause other balance issues, particularly off power.
I actually liked the gear diff at Whalan but that's because the grip is available and the car felt like it flowed through those mid speed corners better. At Castle Hill you definitely need the front driving to pull the car out of the corners because there is no grip. With spool / ball diff I am able to get on the power quite early but with the gear diff all the car wanted to do was swap ends...
vr01 is offline
Old 04-19-2011, 01:45 PM
  #7423
RC MARKET's Avatar
Yes !
Attached Thumbnails T.O.P. Racing "Photon" 1/10 EP Touring Car-mp-tp-0004.jpg
RC MARKET is offline
Old 04-20-2011, 08:41 AM
  #7424
Luppi Stefano's Avatar
Originally Posted by RC MARKET
Yes !
I know you have them, but was looking for something compatible to be taken in Italy ...
Luppi Stefano is offline
Old 04-20-2011, 10:27 AM
  #7425
OVA
OVA's Avatar
yes it does...
OVA is offline
