T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 09-06-2010, 04:26 PM
  #5596
paraletic's Avatar
Cheers Tony
do they wear ok?
Not gonna wear out faster than the standard belts?
paraletic is offline
Old 09-06-2010, 05:52 PM
  #5597
MikeXray's Avatar
Trader Rating: 73 (100%+)
One thing to remember is to check how long your grub screw is on your pinon I have had it catch on the belt and do some damage.
MikeXray is offline
Old 09-06-2010, 06:03 PM
  #5598
stiltskin's Avatar
Trader Rating: 103 (100%+)
Originally Posted by paraletic
Cheers Tony
do they wear ok?
I've only been using them for a few weeks, but I haven't seen any rapid wear. I'm sure that they will wear faster than the stock belts. Just makes sense to me, but I wouldn't buy stock in them. They're holding up just fine and I haven't had to make any adjustments in the tension yet.
stiltskin is offline
Old 09-07-2010, 08:43 AM
  #5599
Trader Rating: 17 (100%+)
Well I got my Photon (USED) . For the last 3 days I have been going through it, cleaning, fixing broken parts, and just getting to know the car.
I have a spring question for you all. Do they make a spring kit? For the most part I have always raced X-ray? can you use those springs? I ask becasue I have a full X-ray spring kit, and well dont have any spring for the photon.
Mr.A Morris is offline
Old 09-07-2010, 08:49 AM
  #5600
yokemad's Avatar
Yes You can use Xray Springs
yokemad is offline
Old 09-07-2010, 11:54 AM
  #5601
Luppi Stefano's Avatar
I use Foam bumber Hard from Duratrax
maximum protection, for Bodyshell and the front car.
I tested them...
results:
My Car perfect
Your Car Broke a Wheel
Luppi Stefano is offline
Old 09-07-2010, 12:11 PM
  #5602
Ericjooopuntnl's Avatar
I'm using mine since almost a year on two Photons (driving twice a week) and none of the white belts have had much wear on them; the belts are superstrong!!
Eric
Ericjooopuntnl is offline
Old 09-07-2010, 02:09 PM
  #5603
paraletic's Avatar
Eric
That's good to hear
I'll have to grab some
Old 09-07-2010, 04:44 PM
  #5604
hana166's Avatar
I tested them...
results:
My Car perfect
Where can I get this Part? Part number?
hana166 is offline
Old 09-07-2010, 06:27 PM
  #5605
macdude's Avatar
I tested them...
results:
My Car perfect
Where did you get the lipo braces from? They don't look stock.
macdude is offline
Old 09-07-2010, 06:44 PM
  #5606
stiltskin's Avatar
His lipo braces look to be a modification of the original plastic ones with some purple shims.
Old 09-07-2010, 07:12 PM
  #5607
mazmo's Avatar
+1
mazmo is offline
Old 09-07-2010, 11:57 PM
  #5608
has anyone got any info as to what weight of oil to use in a m-pro gear diff , i did ask before , but never got a reply ..
its for on carpet , spool up front and gear diff in the rear ...
shaun207 is offline
Old 09-08-2010, 04:07 AM
  #5609
stiltskin's Avatar
I haven't tried them on carpet yet, but Marcos J is running 10k in the rear on carpet. I'm running 10k also on asphalt.
Old 09-08-2010, 04:54 AM
  #5610
toby333's Avatar
Hello Tony. Regarding your fan setup pictured in the last page or two, do you get a better cooling effect just by glueing the fan to the chassis blowing on the motor as opposed to using a fan attached to a motor heatsink?
And on the topic of diff grease/oil, what viscosity grading system are you using? I've got a couple of u-pro gear diff's now, just running the rear straight out of the packet and I know I have to change the oil in the front for a stiffer action. 120K(?) i see is the go..
Cheers.
toby333 is offline
