T.O.P. Racing "Photon" 1/10 EP Touring Car
#5161
My rear diff-dust covers seem to scrape on the rear bearing cap when rotated
in the manual it shows a distinct gap between the two after assembly yet mine didn't seem hav that
I've checked 3 times an the bearing shim is in place
any ideas?
Also the drive train doesn't seem very "free"
I havnt ran it yet - no elecs in it yet - plus it's not finished
will it loosen up after a few runs?
Front belt seemed excesivly tight on kit settings so I've loosened it up by rotating diff cams
this seemed a tad better on the freeness of drive train but still very stiff/tight
any ideas?
#5162
And yeah front belt seems tight on stock cam setting, I also set mine looser, just small details like that and mine was very free once sorted.
#5163
Cheers
was almost tempted to put both bearing shims on the diff pulley side
I'll flip the pulley tommorrow
yea I noticed the spur pullies ran very close to top deck was gonna take a file to the deck
yea I took one shim off an fitted with just one so maybe I need to recheck the shimming - I left no shim on the side with the "leg" of the shaft an one kit shim on the otherside, will check that also
thanks for input
thanks for input
#5164
Cheers
thanks for input
thanks for input
#5167
When u say about the bearing cams(diff) fully seated and ease of fitting camber plates....
My camber plates had approx 0.5-1mm gap between the bulkheads and the bearing cams/caps
should the have been flush? I tried pushin them in further an checked but that was bout as good as it got
I'll give the topdeck a kiss with the file I think then double check the spur/pulley setup
also flip diff pulley
#5170
When I was racing nitro wwaayy back in the 80's, we used toothpaste to lap/break-in a new engine or a rebuilded one. Even ran it on the track with the toothpaste and fuel for one tank to help break-in the engine. Toothpaste probably help break-in the gear diff. Break-in by holding one wheel and slowing applying power to 1/3-1/2 throttle for 30 seconds, repeat on the other side just like breaking in a ball diff.
#5174
If the bearings on the center pulley are not seated fully, it will also put alot of drag on the drivetrain.
