T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 02-21-2010, 02:53 PM
  #3661
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
I want to say thanks to A.J. for the help with the set ups , now i just need to calm down and drive it
Marcos.J is offline
Old 02-21-2010, 04:29 PM
  #3662
Khador12's Avatar
I am really liking the Photon. I have been running it with rubber tires and 17.5 in a 10.5 foam class. I am able to run lap the same lap times with them! My problem is that the car is loose on corner entry. My lap times are inconsistant because of this. I attached my set up so if anyone can help me?
File Type: pdf
Khador12 is offline
Old 02-21-2010, 04:39 PM
  #3663
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
1) Ditch the rear bar.
2) Put a 1.2 bar on the front (or no bar).
3) Move your rear shock position in one hole at the tower.
4) Change rear camber to 2.5mm.
5) Raise ride height to 5.2F & 5.4R.
mrrcguy is offline
Old 02-21-2010, 05:31 PM
  #3664
Khador12's Avatar
Thanks for the reply. I will try that at the next race.
Khador12 is offline
Old 02-22-2010, 11:30 AM
  #3665
Can someone give me a good foam tire set-up? My local hobby shop still runs foam. I also need a rubber tire set up so when I go to bigger races and other tracks that run rubber I'll have a set-up for my rubber tire car. Thanks
kobiwan is offline
Old 02-22-2010, 11:42 AM
  #3666
vr6cj's Avatar
Trader Rating: 124 (100%+)
Just got me one of these bad boy photons too. I'll be running aspault 13.5 and 17.5. Anything from the kit setup that should differ on really smooth high taction aspault? I lso noticed the LF belts. SHould I go ahead and get those?
thanks
vr6cj is offline
Old 02-22-2010, 12:08 PM
  #3667
Regional Moderator
mrrcguy's Avatar
thanks
This car is GOLD on asphalt! Just build it, run it, and report.
mrrcguy is offline
Old 02-22-2010, 02:42 PM
  #3668
can anyone tell me what springs come in the foam kit?
kobiwan is offline
Old 02-22-2010, 04:45 PM
  #3669
kschu's Avatar
Trader Rating: 16 (100%+)
thanks
the lf belt seem like not as durable as the normal one....and it's just alittle different , i think softer alittle bit...
kschu is offline
Old 02-22-2010, 05:03 PM
  #3670
adamge's Avatar
According to the documents I have,
PS-TF17675 560gf/mm
PS-TF14625 306gf/mm
adamge is offline
Old 02-22-2010, 05:25 PM
  #3671
odpurple's Avatar
PS-TF17675 560gf/mm
PS-TF14625 306gf/mm
That is correct, thanks Adam
odpurple is offline
Old 02-22-2010, 05:26 PM
  #3672
Suspended
RaceAce701's Avatar
Trader Rating: 87 (99%+)
oh no ur switching to the RED side
i use a modified form or the haloween classic setup
see me sunday
RaceAce701 is offline
Old 02-22-2010, 06:23 PM
  #3673
odpurple's Avatar
Default Something New
USA Spec Foam kits
USA Spec Rubber kits
Now in stock at TOP Racing USA!
odpurple is offline
Old 02-22-2010, 07:10 PM
  #3674
adamge's Avatar
Details on these "USA Spec" kits?
adamge is offline
Old 02-22-2010, 07:16 PM
  #3675
haywood's Avatar
Trader Rating: 49 (100%+)
Default Spec kits
I talked to Micheal today and I believe you will recieve some additional suspension parts with the new kits as a added bonus!
haywood is offline
