T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 08-05-2010, 06:41 PM
  #5176
tallyrc's Avatar
Originally Posted by AdamD
Just give Michael a call at TOP Racing USA I'm sure he can hook you up with a gear diff. 650-583-8898.
are they in stock?
tallyrc is offline
Old 08-05-2010, 07:39 PM
  #5177
R/C Tech Elite Member
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Originally Posted by MikeXray
Tony, did your gear diffs free up after some use? I just got mine, part of me wants to use some old school diff breakin techniques, part of me wants to just run it
It took mine about 5 runs, I took it apart cleaned the stock grease , filled it up with 10,000 diff fluid and now is smooth as butter
Marcos.J is offline
Old 08-05-2010, 08:11 PM
  #5178
paraletic's Avatar
Build was goin well till had do the sway bar mounts
seeing as they a drilled out alloy thread I decided to pre tap/thread the ball cup using the grub screw, so there shouldn't be any tension on the alloy collie when threading into the cup
well soon as it was half turn from being snug (not tight just snug) it sheard off inside the cup
WTF!! 3 went together well by pre threading the cup using the steel grub screw but the last one snapped off
pretty shitty with that
so much for gettin a run with it prior to my state titles (not running it without some decent track time an testing)
by time I get another one in from over seas will be bit late
seems T.O.P aust are closed for there move
Looks like I better get back to my old chassis an get that ready
paraletic is offline
Old 08-05-2010, 09:07 PM
  #5179
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
I do fairly well and I almost never run any bars on this car ever. I actually hate swaybars with a passion. Give it a shot without bars you might be surprised.
L.Fairtrace is offline
  #5180
Hugh Jazz's Avatar
Robbie will be at the SA Titles so you to can compare setups.
Hugh Jazz is offline
Old 08-05-2010, 09:17 PM
  #5181
paraletic's Avatar
Yea mite have to try it without for now
as I'm dyin to give it a shake down run an can't see me gettin parts for it in a hurry
thanks Hugh, yea have to see how I go with it first up
gotta get set up to my driving style etc an get comf with it
otherwise I'll play safe n run the ol xxx-s
Old 08-05-2010, 09:51 PM
  #5182
paraletic's Avatar
Am I correct in thinking that when using the mid size servo saver on the lipi chassis that I hav to reverse the servo mounts an fit the servo to the outer holes on the chassis?
If I mount it as per the instructions the servo saver fouls on the top deck
this then puts the servo further away from the centre line of the chassis - hence it hangs out over the edge of the chassis alot more
I'm running a JR-DS8915 servo if that helps
Old 08-05-2010, 10:41 PM
  #5183
Bishop's Avatar
I needed like 1-2mm of extra spacers and mine is fine, but yeah you can mount it on the outside holes although I'm not sure that is what they are there for, but some have done it that way, I considered it but I'm using the current gap to tuck in my wires until I can shorten all of them.
Bishop is offline
Old 08-06-2010, 07:36 AM
  #5184
paraletic's Avatar
How does one measure droop on these cars
ie: where do you measure from?
I have a team magic droop tool with two t-bar blocks to sit under the chassis and then the droop gauge
I'm guessing I measure the rear droop on the arm itself just in front of the loop?
And the front droop off the c-hub ??
I've never been the best at doing droop etc
kit set up states 5.5mm
so on my gauge it has -2, -1, 0, 1, 2, 3 etc etc so id set it halfway between my 5 & 6 marks on my gauge? Or would this be wrong (my Gauge is stepped not constant slope)
thanks for any input
Old 08-06-2010, 12:11 PM
  #5185
Marcos.J's Avatar
I do mine with a droop gauge on the bottom of the arm( to make sure they are the same left and right) then I mount the wheels and redo the droop with a ride height gauge(over ride height)
Marcos.J is offline
Old 08-06-2010, 01:07 PM
  #5186
For you gear diff gurus...
Are there advantages for using only 4 internal gears (besides lightweight) as oppose to the 6 internal gears like the Spec-R design?
Thanks..
cvccsi is offline
Old 08-06-2010, 06:33 PM
  #5187
MikeXray's Avatar
Trader Rating: 73 (100%+)
I can say from the parking lot test that dropping in a gear diff will give you onpower snap, right around snap I'm expecting it to be better at the track, but I think I'd leave the ball diff in any low traction scenarios for sure.
MikeXray is offline
Old 08-06-2010, 08:53 PM
  #5188
pakk's Avatar
Trader Rating: 80 (100%+)
Default one-way and flipped belts
Is anyone running a one way and flipped belts? Can you just move the pulley to the other side?
pakk is offline
Old 08-06-2010, 08:54 PM
  #5189
Marcos.J's Avatar
you would have to flip the oneway bearings inside the axle.
Marcos.J is offline
Old 08-06-2010, 09:00 PM
  #5190
pakk's Avatar
I'm not familiar with construction of the photon one way. Is that something you can do?
In my TC5, I just moved the pulley to the other side, but I had to add spacers to get it to sit right.
pakk is offline
