T.O.P. Racing "Photon" 1/10 EP Touring Car
#3422
Hi here
Any one has some good setup for the foam spec that i should try?
i am a pretty newbie to touring so any help is good
The thing's i have done is just added some anti-caster at front and added 800 oil in front shock's and 550 in the rear shock and added 1,2 swaybar at rear. this helped alot in the consitency of the car but i feel the diffs are not quite where i want them, they are slipping from stand still. If i thight'en them more they are getting more gritty What should i do here?
I cant help you with a setup, as i am running rubber tc, but i can help you with the diff problem, you have to sand the diff rings down, they are a little uneven, i start with 1000 wet sanding paper, and end up on 2000 wet sanding paper.
If you dont already have it, get a set of ceramic diff balls, end up with RGP diff grease, and your diff is bullet proff!
#3423
Larry,
thanks for the input and the explaination. Once we put those wide hexes on the front of the car, with that one simple change, it was butter (with a setup that's very similar to the one that you posted previously). Unfortunately, the other Top guys didn't happen to tell me about the optional wide hexes until after the race day was over. But in post-race practice, soon as we put the wider hexes on....the thing was really good and it's handling stayed consistent throught the whole run. For the first day with this car, I was impressed with it and very satisfied. Now that its late run handling issue is fixed, I'm really looking forward to the next outing. Seems that there's lots to learn in this sedan area. Already I've learned that only a little of my experience from so many years of pancar racing will tranfer to the bigger cars. Lots of stuff about sedan racing will need to be learned from scratch. At least I've got a good piece to work with and a group of good guys to learn from.
Perry
Perry
#3424
1mm wheel spacers will have the same effect as wide hexes.
If you're not already running them, ceramic balls in the diff (and new diff plates) are a must.
#3429
Regional Moderator
Hi here
Eight is the correct number but often seven works as well.
#3431
Limited Shipping Jan 27-29
TOP USA Customers: We will be doing limited shipping Jan 27-29. Michael needs a break. LOL Actually we are doing inventory.
You can send in your orders, but nothing will be shipped out until next week.
#3432
#3433
You should really have a fulltime inventory guy like me Where I work I inventory everything every 2 months
#3435
