T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 01-19-2010, 07:44 AM
  #3391
smilekt's Avatar
Originally Posted by kschu
have u try use the TOP servo tape for servo without the servo mount ???how is they holding ?? good ??
im already using it. no problem at all .. but need thick double tape to make the servo more static ...
smilekt is offline
Old 01-19-2010, 07:48 AM
  #3392
smilekt's Avatar
if u use only the servo tape, u can make your motor side lighter few gram and you can move your servo alittle into the middle...maybe around 2-3mm...which will convert alittle weight to the middle...then left n right balance will be better....
my 2cent opinion....
im agree with u ...
smilekt is offline
Old 01-20-2010, 12:47 AM
  #3393
Default New Photon for sale
Hello,
I have a brand new built Photon for sale. Asphalt edition. Please see my for sale thread if interested.
Thanks!
losi offroader is offline
Old 01-20-2010, 10:39 PM
  #3394
E.J. Evans's Avatar
Default Snowbirds
I know Josh, Schreff, Larry, and Justin will be there. Who else will be there running a Photon?
E.J. Evans is offline
Old 01-21-2010, 05:43 AM
  #3395
MAD916's Avatar
Timezone will be there I'll be running my Photon in 13.5 foam was a killer car last weekend at round #3 of the NWIC, spending the week putting all the new kibbles and bit's on it.
MAD916 is offline
Old 01-21-2010, 09:05 AM
  #3396
E.J. Evans's Avatar
Old 01-21-2010, 11:18 AM
  #3397
Rick Vessell's Avatar
I'll be there running mod.
Rick Vessell is offline
Old 01-21-2010, 04:25 PM
  #3398
tallyrc's Avatar
who sells the roche spool stateside? tired of toasting the factory one, even with steel outdrives..
tallyrc is offline
Old 01-21-2010, 04:31 PM
  #3399
smoke81's Avatar
I've ran the same spool since vegas till the novak. I replaced it, but its sitting in my box as a spare. Nothing was wrong with it just figured it would be a bad time for it to let go if it did... Wonder whats going on.. You are using the V2 spool right?
smoke81 is offline
Old 01-21-2010, 04:32 PM
  #3400
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
You are toasting the spools with steel outdrives? That is crazy
I have been running the same spool in my car for probably 6 months. Its actually the first version 3 spool I ever got still in my car.
And I have run nothing but 13.5, 10.5 and mod at least one day a week usually 2 for the last 5 months.
L.Fairtrace is offline
Old 01-21-2010, 04:40 PM
  #3401
tallyrc's Avatar
dunno what version spool it is but the outdrives came from top less than two weeks ago.. are all the spools this flexy?..
tallyrc is offline
Old 01-21-2010, 04:47 PM
  #3402
Are you using the stock machine screws to hold the outdrive on? Those strip the spool easily and you should get some screws with a more aggressive thread
I bet your problem is the screws loosening up and the outdrives wobbling around eventually rounding off the spool inside. my spool has atleast 50 runs on it and its still perfect (altho my tracks walls are forgiving)
JustinLessard is offline
Old 01-21-2010, 05:01 PM
  #3403
tallyrc's Avatar
the screws that came with the drives..
tallyrc is offline
Old 01-21-2010, 05:03 PM
  #3404
LOW ET's Avatar
Trader Rating: 109 (100%+)
i thought this problem was taken care of when they made the spools with the newer material
LOW ET is offline
Old 01-21-2010, 05:15 PM
  #3405
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
I think you still have an original spool. The newer spool is made of a harder material and the screw hole is slightly smaller. If I were you I'd order a new spool from TOP USA and also I'd run the alum spool cups. The steel cups have no give in them so when you hit something you either bend the dog bone or break a c-hub/knuckle. Just be sure to stock up on blades.
Ron Goetter is offline
