T.O.P. Racing "Photon" 1/10 EP Touring Car
#2671
#2672
A-main hobbies stocks the parts and TOP Racing USA always has what I need. Every order I've made from TOP has been at my door in two days. You can't beat that. The only part I've broken was the steering bellcrank after a very hard hit. I did replace my spool cups today because they were developing some slop. I believe that most people are moving to the steel outdrives or the Titanium Racing spool. Very good car.
#2673
does anyone know if T.O.P. is going to offer a 2deg rear hub eventually
#2675
On the topic of spurs, I've actually chosen to trim the outer edge of the pegs of the spur adaptor rather than ream the spur gears (I have a Kawada on it but the Kimbro also fits after this mod). The downside of this is you lose a little material for the screws to grip.
Hopefully some Photon-specific spurs should be available soon.
#2676
#2677
Running outboard toe-in (ie.. hubs angled in at 2 degrees) allows the suspension to operate with less binding. It gives the car a different feeling on the track. You have to move the arms forward on the hinge pin also to get the same wheelbase since the spacers are not angling the arm forward.
#2678
#2681
Trader Rating: 27 (100%+)
hey what are your guys feelings about this car on high bite asphalt?
#2682
good to know because im ready to switch cars now! my tc5 jus isnt cutting it anymore where my local track is dominated with xrays!!!! haha i have to be different.
#2684
EJ & OD - Thanks for da hook up!
P2
#2685
how is its performance on modified class racing? and its durability?
