T.O.P. Racing "Photon" 1/10 EP Touring Car
#3377
#3378
(shameless product plug)
I used to use Parma servo tape for my electronics. Because of my OCD, I couldn't stand mounting everything perfectly straight and then watching it shift over time. I started to shoe goo everything down. (problem solved) I picked up some servo tape from T.O.P and gave it a shot. VERY sticky and thin. Mounted everything up and it stays right where I put it. Good stuff.
#3379
#3380
I have now the Roche spool in my car.
Wanted to wait till my old spool was broken but the spool looked so good and I mounted in the car.
Here are some Photo's of the spool in my car.
The yokomo ring has a higher side as the TOP spool has. No I don't have to worry that my drive belt stays better on after a big hit.
I loosened my drive belt again.
#3384
Hi!
here a video my weekend race
my car leaves from the first start grid
http://www.youtube.com/watch?v=V8d-XYtAIbo
#3385
Servo not center after turning right
Hi All,
I have ran into an issue on the Photon where the steering is not centered after turning to the right. The servo returns slightly to the right but not centered; however, turning to the left, the servo will return to the centered position.
I am using Airtornics FHSS-3 receiver with Futaba 9451 servo. I have tried a different servo and the problem is still there. Any suggestion?
Thanks.
Thanks.
#3386
can support RC3 system ?
#3387
Hi All,
Thanks.
Thanks.
#3389
Hi All,
Thanks.
Thanks.
#3390
Disconnect the servo and make sure that you have full steering throw and return with all the mechanical linkage and there is no binding. If all is good, hook the servo back up without power. Turn the wheels (slowly) to full lock in each direction and make sure that the servo will give you full throw. If not, disconnect your servo horn, center the servo and try again. Make sure that the servo linkage is not binding on the servo case. If it still doesn't work, let me know what it's doing.
The servo gives me a full throw in both direction. Check everything and nothing seems to bind.
After turning the wheel to the right, the servo will stop short to the center, maybe about 1mm. Turning to the left, there is no problem for servo to return to the center dead on.
Thanks.
