T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 07-14-2010, 12:22 AM
  #4876
DaveW's Avatar
Originally Posted by dex410usa
Any one having the issue of rear tow being different from left to right? I attached a picture of rear.
Thank you
Looks to me like you have too many/too thick of shims on the left versus the right between the bulkhead and the arm mount?
DaveW is offline
Old 07-14-2010, 12:25 AM
  #4877
Skitee's Avatar
I think that is what he had to do to get the toe equal left and right
Skitee is offline
Old 07-14-2010, 05:12 AM
  #4878
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
This happens when you tend to hit alot of stuff or have the same Plastic roll center holders on for a long time and they are bent. If you change out your roll center hingepin holders with new ones it should fix the problem.
L.Fairtrace is offline
Old 07-14-2010, 06:01 AM
  #4879
Nova F1 Racer's Avatar
Wiring tip for the Tekin ESC...
Tired of soldering the wires to the posts and heating up the circuit board might damage it? Here is what I did to solve the issues and only soldering the connectors just once...
1. Tin the ESC solder posts...
2. Purchase 5 female 3.5mm diameter gold plated "Super Bullet" connector
3. Tin the insides of connector ( use a small tip )
4. Heat the post and connector and slide on, make sure the low part is facing out.
5. Solder the bottom of the connector and the post to make sure it’s a joint
6. Removed by popular demand...
7. Solder the wire to the top of the connector and you are done...
Attached Thumbnails T.O.P. Racing "Photon" 1/10 EP Touring Car-ptk-5034.jpg
Nova F1 Racer is offline
Old 07-14-2010, 07:18 AM
  #4880
Trader Rating: 21 (100%+)
5. Solder the bottom of the connector and the post to make sure itís a joint
6. Put shrink wrap over the connector.
Putting shrink wrap over the post is not good. The posts are heat sinks.
lidebt2 is offline
Old 07-14-2010, 03:22 PM
  #4881
Originally Posted by Skitee
That is a massive difference you definitely have something that's bent, check the hinge pins, hinge pin holder screw and the rear bulkheads.
The car is brand new and never been on the track yet!! Checked screws, bulk head, chassis, tweak, everything!! I am getting reports that the hinge pin holders might have a size difference. I am trying to use some xray hinge pins holders just to check, if that does not work i will be sending to tops to see if they can help. I did measure the hinge pin holders and there seems to be some difference. I am trying to see if the xray hinge pins would work just to test.
dex410usa is offline
Old 07-14-2010, 03:38 PM
  #4882
MikeXray's Avatar
Trader Rating: 73 (100%+)
Thank you
even if the blocks were messed up, it wouldn't be THAT much. Are both hubs solid with no play?
MikeXray is offline
Old 07-14-2010, 05:09 PM
  #4883
No play in the hubs.
Old 07-14-2010, 05:17 PM
  #4884
MikeXray's Avatar
What setup tools do you use? my hudy stuff requires me to remove the body posts to get an accurate toe reading in the rear, make sure the gauge isn't hitting them.
MikeXray is offline
Old 07-14-2010, 05:22 PM
  #4885
Suspended
RaceAce701's Avatar
Trader Rating: 87 (99%+)
have you checked you shims behind the front rear blocks
also make sure that the height adjuster are fully seated in the pivot blocks
RaceAce701 is offline
Old 07-15-2010, 10:03 AM
  #4886
locked's Avatar
Well I had my first ever trophy race this past Sunday. Despite having some traction issues that I never fully resolved, I finished 3rd in the B main. For my first real race in a class that is generally considered way too fast for a beginner (13.5, open esc), I'm pretty happy with that.
The only other Photon at our track TQ'd and won the A main against some tough competition. He recently switched to the Photon from a TRF416X. Man, his car was on rails. Nicely done Martin!
Anyway, I just felt like sharing.
Cheers
locked is offline
Old 07-15-2010, 10:47 AM
  #4887
Trader Rating: 80 (100%+)
If anyone is looking for Top Racing Photon parts, I have a group of parts that im selling. Let me know.
http://www.rctech.net/forum/r-c-item...ton-parts.html
cpatel529 is offline
Old 07-15-2010, 10:57 AM
  #4888
OVA
OVA's Avatar
Trader Rating: 87 (100%+)
Cheers
You mean Martin C.switch to Photon from 416X Tamiya??
Hard to believe....
OVA is offline
Old 07-15-2010, 11:51 AM
  #4889
locked's Avatar
Hard to believe....
Yeah, I was surprised too when I walked over to his table and saw the red ano instead of blue. I thought I was the only one with a Photon. He said he switched about a month ago.
I'm also a bit surprised you know exactly who I was referring to OVA
locked is offline
Old 07-15-2010, 01:13 PM
  #4890
E.J. Evans's Avatar
Thank you
That's a hugh difference between left and right. Someone already asked, but what gauge are you using? Have you tried flipping the gauge around and rechecked?
Another crude method to check toe is to stand the car up perpendicular to a flat surface and use a standard camber gauge. Do these things and let us know your results.
E.J. Evans is offline
