HPI Cup Racer 1M
#377
Dammit I smell troll.
#379
I had the same issue.
Use one of the longer screws to pull the hex into the cv joint (though the wheels).
then remove the longer screw and use the correct size.
That did it for me!
hope it helps!
That did it for me!
hope it helps!
#380
#381
#385
All of you guys respond the same way .. all get upset when someone dares to make a comment about the stupid design of the car that you have purchased.
The car could have been far better with the use of a simpler design in a number of areas.
I have no personal problem with HPI. The last two mini size vars have however got a massive number of design flaws. Look at other peoples reviews of the Switch.
BTW, I did mention where the problems were if you bother to read back more than 3 posts.
The car simply has a number of design features not needed on the car.And these features do not work.
But keep your heads buried in the sand guys
#386
^^^ you are boring with your monday night quarterbacking, i dont see any benefit from your post.
#387
So we shouldn't mention any problems at all?
Not very fair on guys who maybe are still deciding on whether to buy the car or not.
So far the obvious design problems include:
Strange wheel fixings when a simpler system could have been used
A battery fixing system where you see the majority of batteries "dangling" by tape from the underside of the top deck !!!! And near impossible to fit the more commonly accepted lipo stick pack style that is used by the 2WD Mini guys
#389
I just believe the racer should be informed of problems etc. Then it is their choice whether they buy or not.
If you want I can sell you a Cup Racer cheap. Never raced. Not even painted
FYI, in the past I have criticised the first Losi JRX touring car for its design faults, the TC5 is not much better. And interestingly enough the things I mentioned were the first things that the manufacturers changed because they were faults
Hey, guys enjoy your car.
#390
the 1M 510 kit is already out at my LHS, very tempting if i didnt already have one.
