HPI Cup Racer 1M
#331
#332
Finished my cup racer last week.
Haven't had it to the track yet...
here's some pics..
here's some pics..
#336
#337
Yes, complete PRO4 front spool and bevel gear for the front. It is a few mm narrower than the Cup Racer diff so the dog bones aren't as deep into it but because the spool is metal it seems to have plenty to hold the dog bones in. For the rear I'm using the stock diff outdrive but am using the PRO4 bevel gear. The PRO4 bevel gears are very close tolerance against the pinion gear and diff cases but I've put 3 packs through my car and it all is running very smooth, if not better each run.
Not sure what car they were for but they are 3mm and about 20mm long.
For the pins I wanted to see if I could simplify the knuckle stops that came with the car so on one side I just bolted a m3 screw into the upper arm. Seems to work ok so I went ahead and put it on both sides. Note the steering plate on the knuckles are moved to the top side and flipped over to reduce most of the bump steer the car had before. Used tamiya ball end and cup to complete it so that it didn't rub the upper arm.
See above.
See above.
#339
Setups
Anyone seen a setup sheet for the Cup racer?
I can't find one on the HPi website.
It would be nice to see to setup the car correctly.
#341
Can you run the shocks in "stand up" on the Datsun body? The kit lets you choose stand up and lay down?
Lets please get some more pix! Especialy with the battery mounting w/lipo
I want a Beetle Cup Racer HPI!!!!!!!!!!!!!!!!!!!!!!!!!
Paul
Paul
#342
Hi, I'm planning to buy one for my self, but thinking on getting the Drift version and would like to get a Toyota Celica ABC body.
Has anyone tried drifting if and how does it handles?
#345
^^^ i got the drift spec with a MM 4600kv its a handfull. gonna put a trinity 27T in there and see how it handles.
just finished painting an ABC 510 and statrted on the sticker sheet. bumper and leds next.
