Veteran TAMIYA TA03 fans!
#1381
You could fabricate sway bars with a metal coat hanger and save some $$$. It's very easy and you can use stiffer steel if you want so they actually do something. The neon bars are very cool looking though, my f has them just for show. Adjusting droop did way more to keep the car flat and not traction roll than sway bars.
#1382
That sway bars for $50.00 is too spensive. There's no way I pay that for those.
#1384
another question for the veterans
this part fits my TA03F with no issues???
#1387
Btw I went up to MRH tonight to race vta but they only ran 17.5 tonight
#1391
Ta03 conversion
Let me tell you guys what I doing guys so maybe I got a little bit of help here. I am converting my Ta03f to the pro version, one thing that that I should do is to convert my gear diff to ball diff but I don't want to mess with ball diff so y buy the one way diff I installed on the front and leave the original gear diff on the rear got the upper and lower frp chassis an the ta03 pro white gears now the counter shaft is half black and has white, got the battery carbon plate and the aramid fiber belt with no tensioner for now I am planning to buy a speed passion 17.5t and reventon esc combo y need help with the pinion gear.
#1392
Here is a link that shows the gear chart on the manual.
http://www.tamiyausa.com/pdf/manuals/58177ml.pdf
#1393
Tamiya should re-release this chassis permanently and create a 03 Spec class for TCS.
