Veteran TAMIYA TA03 fans!
#1351
You should probably contact the guy on this link. I haven't seen any aftermarket pulleys that were not 15t or 16t. Although it would be pretty sweet!
#1352
Cheers, I will take a look
#1353
Need a little bit of help for the tao3f whats the diference between the manta ray diferential vs the regular ball diferential?
#1355
I buy a tao3f and I buy the pro upper deck and the hop up carbon battery hold down but is very hard to get lower deck chassis to make the pro chassis conversion.
#1356
Hope this helps.
#1357
They both fit. Manta ray(ta02) ball diff is a bit heavier, but the diff action feels smoother and a little looser than ta03 diff IMO. Ta03 ball diff comes with better thrust bearing.
#1359
#1361
I PM you
#1362
I PM YOU. Thank you
#1363
still looking for A ta03F lower deck help!!!
#1364
What kind of lower deck are you looking for? CF?
I got lucky and found my set on eBay but then again that was 2 years ago. I did however come across a place that still has the CF saddlepack conversion.
The saddlepack chassis makes taping down a pack alot easier. But it also opens up battery configurations for the car as well as different places to mount your electronics.
#1365
oops! How the hell you delete a double post?
