Old 02-17-2009, 09:22 AM   #20221
SRBMOJO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by TryHard View Post
hmmm, not sure about that...
Most of the time, we ended up running 3-hole pistons, with slightly heavier oil. Also removed the red foam piece from on-top of the shock, which helps reduce the pack and make the car smoother overall.
Raising the roll centres does work... but I personally never went above 1.5mm (and that was on a very quick track, with a 27t), but that did carry awesome corner speed.
Something else that was done as a general rule of thumb was white/blue springs, and no roll bars. Have a look here, if you haven't already for a number of setups that work well THard 415 pages.
HiH
Ed
Do you use a oneway (front or center) front diff or spool?
ALL TAMIYA 4 WHEEL DRIVE ALL THE TIME
TRF-416X, SP CIRTIX, LRP X-12 17.5, FUTABA 9550
SRBMOJO is offline   Reply With Quote
Old 02-17-2009, 11:54 AM   #20222
TryHard's Avatar
When running the 27t, I always preferd the one-way, as it carried the corner speed much better, and suited my style.
With faster motors, I prefered the spool... especially now with brushless, as you can loose the drag brake to help keep the speed up.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 02-18-2009, 02:07 AM   #20223
Skitee's Avatar
TryHard do you know if it's possible to run the 37tooth diff pulleys and 18tooth centre pulleys on the 415, if it is indeed possible what belts would you need to make it work?
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 02-18-2009, 02:22 AM   #20224
tc3team's Avatar
HiH
Ed
+1, i've always prefered a centre one way over a fixed centre with 27t, especially at bigger tracks. I've never experimented with the front one way as i've found the centre one way is a little more neutral and you can keep a little more brakes with it, probably not much more, but a little should you need them.
On very small tracks, where corner speed isn't so important, i'd be going with a fixed centre layshaft. I've found that you can scrub off a little bit of speed on turn in if need be.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 02-18-2009, 03:01 AM   #20225
piper48
Guest
Posts: n/a
Does anyone know a good online hobby store that stocks 415MRE parts? What I'm looking for is a rear or front differential pulley, center one way pulley, and a rear aluminum diff joints. Hit me back, anybody!
Old 02-18-2009, 04:52 AM   #20226
tc3team's Avatar
Not sure if they're in stock and may be too far away for you, but you could always try shooting an email to Fusion Hobbies to see if they have any of them?
Old 02-18-2009, 09:01 AM   #20227
SRBMOJO's Avatar
www.ampdraw.com
Old 02-18-2009, 10:27 AM   #20228
piper48
Guest
Posts: n/a
Thanks guys, I found a couple of other websites but I wanted to order straight from one site. I'll check out Fusion and Ampdraw and see what I can find.
Old 02-18-2009, 09:24 PM   #20229
Chill_Will's Avatar
Trader Rating: 32 (100%+)
Also check out Speedtechrc.com
A-Train racing (Woooooo Wooooo!!)
Chill_Will is offline   Reply With Quote
Old 02-19-2009, 11:59 AM   #20230
try vellrip
he was a seller i used for some spool parts from ebay
but he has opened a shop
the postage is cheep if you order a few things
and he is SOOOOOO quick with postage i cannot recommend him enough
http://www.vellrip.com/store/home.asp
sidecarphil1 is offline   Reply With Quote
Old 02-20-2009, 11:13 AM   #20231
STLNLST's Avatar
Trader Rating: 21 (100%+)
UPS should be here this afternoon so I can put my car back together and be ready for racing next Saturday. I can't wait to run the car again. TRYHARD has some very great info on his website. If you haven't checked it out yet I suggest you do so.
STLNLST is offline   Reply With Quote
Old 02-20-2009, 01:44 PM   #20232
Csaari77's Avatar
Trader Rating: 34 (100%+)
What is the difference between the front upright that is used in the MSX, and the new one that comes with the 416? Can the new one be used with the LW suspension on a 415? I've been having trouble finding the LW front upright, so I was wondering if the new version can be used in it's place.
Csaari77 is offline   Reply With Quote
Old 02-20-2009, 11:17 PM   #20233
STLNLST's Avatar
Everything showed up today. Looks like all I have to do is put things together. Next weekend looks like it's going to be fun.
Old 02-21-2009, 09:01 AM   #20234
r_s
416's front upright uses 1050 bearing, MSX's uses 950.
if you want to use 416's front upright, u must also change the bearings and C-Hub to 416 version. CMIIW.
but i don't know the swing shaft, whether it still can use the 46mm swing shaft or must change to 44mm (416 version).
r_s is offline   Reply With Quote
Old 02-21-2009, 01:54 PM   #20235
is there a stronger lower arm for the 415 ??
they seem brittle to me
i'm new to touring car racing (come from M-03 racing)
and i'm trying to learn to drive a TRF415MSXX MRE indoor but as soon as i make a small mistake i break the front suspension arm on the barrier !!
getting a little disgruntled with it !!!
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
