Old 02-09-2006, 05:14 PM   #12721
neosan's Avatar
Originally Posted by Nexus
nice pic LOL :P
As soon as I set up with a host I will be posting my new site. Then I'll relist the diff pics and instructions I had up awhile back. I will also have a few custom painted Tamiya bodies for sale on the site as well. Most likely NSX's. by Slik FX
Yeah !!!! I got in one of your reply !!!! Hopefully you get a host soon !!!
neosan is offline   Reply With Quote
Old 02-09-2006, 08:04 PM   #12722
RayWarner's Avatar
Send a message via AIM to RayWarner
Originally Posted by Turbonium
on the outdrives, they are 10x15....
Nope, inside the diff. Thanks for the help though!
RayWarner is offline   Reply With Quote
Old 02-09-2006, 08:42 PM   #12723
The bearing size inside the diff is 850.
trf_racer is offline   Reply With Quote
Old 02-09-2006, 08:46 PM   #12724
RayWarner's Avatar
So 5x8x?
Old 02-09-2006, 08:50 PM   #12725
Neil's Avatar
Send a message via MSN to Neil
Default 3 mm chassis
I have a 415ms and the chassis was drooping in the middle. So I went out and got a new one 3mm part# 4005103. Why dont the screws line up on the arm mounts? I'm holding the new chassis over the old one. If you look closely you can see all but four screws line up. Do I need to get longer hinge pins? And how does this affect rear toe, kickup, and antisquat?
Neil is offline   Reply With Quote
Old 02-09-2006, 08:57 PM   #12726
maxepower's Avatar
Exclamation MS vs. STD. chassis
The original 415 that used the 3mm chassis came with the standard arm, where as the MS came with the lightweight arms which are narrower so they used shorter hinge pins. You will have to buy the longer hinge pins and add spacers!
I think the changes will be minimual if you space the arms the same as the MS, but with the .5 mm thicker lower chassis you will definitely see a change in the handling!
Just my 2$
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 02-09-2006, 09:01 PM   #12727
Neil's Avatar
Would it be a bad idea to use this 3mm one? I race rubber tire on carpet. Med to high traction.
Old 02-09-2006, 09:11 PM   #12728
maxepower's Avatar
Talking
Thicker is better for carpet!
That's why Tamiya is coming out with a 4mm chassis, just for carpet application!
If you like it with 3mm then maybe try 4mm later on!
Old 02-09-2006, 09:22 PM   #12729
Customworksking's Avatar
Trader Rating: 73 (100%+)
Unhappy 4mm
got a reply from Tamiya today the 4mm chassis will be out late this Month ..It sucks I will need to Next day it to have it in time for TCS @ Trackside
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 02-10-2006, 11:33 AM   #12730
Trader Rating: 37 (100%+)
I can't imagine that the traction at the TCS race will be super high. A 2.5mm and 3mm chassis should be more then enough at Trackside.
Fred K. ran his MSX and won the Novak race easily without a 4mm.
I really thought the 4mm and Diff would be focused more toward those running carpet/foam.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 02-10-2006, 11:37 AM   #12731
Eirik's Avatar
Hey Anthony,
Did you try out my setup?
Eirik is offline   Reply With Quote
Old 02-10-2006, 01:30 PM   #12732
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
i think Anthony(Nexus) is correct.... the stiffer chassis is good for foams, thats why its from Tamiya USA instead of Japan... they dont have any concerns about foams, from what i hear.
on rubber tires, the 2.5 or 3 should be fine... with the rubbers you are looking for more bite, rather than trying to take it away from the foamies..
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 02-10-2006, 04:01 PM   #12733
Sushi Man's Avatar
Send a message via AIM to Sushi Man
THANKS!
Originally Posted by neosan
Hi Sushi Man,
If you are talking in Front Ball Diff, as far as I know, there is no available from Tamiya. You should get some Yokomo parts to build one.
Parts Needed:
Yokomo ZS-501 Diff Halves or ZS-502S for steel outdrives
Yokomo ZS-506 Diff Rings or Tamiya 50880 TA04 Ball Diff Plate Set
Yokomo ZS-507 Thrust Balls and Washers
Yokomo ZS-508 Diff Screw and Locknut
Yokomo ZC-S100 10.0mm spacer shim set
Tamiya 51055 TRF415 Ball Diff Pulley
Tamiya 53379 3mm Lightweight Diff Balls
2qty Tamiya 53030 Ball Bearings
2qty Tamiya 53126 Ball Bearings
cheers
Sushi Man is offline   Reply With Quote
Old 02-10-2006, 04:03 PM   #12734
Sushi Man's Avatar
I dotn even get why tamiya wants to make a 4mm chassis, if u do u will run foams.,.. AND THERES NO FRONT DIFF! lol
Old 02-10-2006, 04:36 PM   #12735
They made a spool, which is also good when running foam tires.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
