Old 02-25-2009, 06:41 PM   #20251
Yeah the tray works good!!!
bigdog is offline   Reply With Quote
Old 02-26-2009, 01:13 AM   #20252
Ricky/C's Avatar
Send a message via MSN to Ricky/C
Originally Posted by Skitee View Post
Maybe TryHard can tell us if there's an advantage to running a lower IR, so if you have 2 identical cars but one has a IR of 2.250 and the other has an IR of 2.055 and both geared to rollout at at 42mm. Would the car with the lower IR have an advantage of any kind?
TRF 416 WE | LRP SPX Stock Spec| 17.5 SP | Sanwa M11
TRF 416 WE | LRP TC Sphere | Novak 3.5 | Sanwa M11
www.oneten.co.za >>>>>>>>>>>>>>>> Home of RC in SA
Ricky/C is offline   Reply With Quote
Old 02-26-2009, 01:21 PM   #20253
Ricky/C's Avatar
Old 03-02-2009, 04:54 PM   #20254
Default Question about 415
Hey guys considering getting a 415. Im undecided between 415 or jrxs type r? Is the parts support gonna be around for a while for the 415 now that the 416 is out or would I be better served to consider the 416. Whats the difference between the two cars 415 and 416. I know alot of questions but when I buy a tc i keep and drive it for a while and try to get familiar with it. I run lipos and brushless so that is something I have to keep in mind with these cars as my current jrxs is extremely unfriendly with the lipos unless you hack it. Any help would be appreciated.
jg24rw is offline   Reply With Quote
Old 03-02-2009, 05:03 PM   #20255
STLNLST's Avatar
Trader Rating: 21 (100%+)
The 415 isn't lipo friendly either. I had to mill mine just to get the Orion 3800's to fit. You can't even think of trying to get a 5000 to fit unless you get the bitty design tray. I plan on trying the tray out because I like the 415. This is also my first Tamiya so I don't have any 416 info to share with you. Many have said that the 416 is faster across the board but until someone here beats me with one I don't believe it
STLNLST is offline   Reply With Quote
Old 03-02-2009, 06:07 PM   #20256
vr6cj's Avatar
Trader Rating: 124 (100%+)
Originally Posted by STLNLST View Post
I think the SMC 4000 may fit under the low bulk heads. I'm running the Orion 3800 but I had to mill the bulk head slightly to get it to fit. There are lipo tray's that push the battery out a bit so running bigger batteries should be fine. Dujuan bought the tray from Stomers and he seems to like the fit. Once I see how it looks in person I may go and get it. No mod for me. I'm sticking with 13.5 for now. That's what I'm running for the Reedy this time around.
Yep, the SMC 4000 28c is the perfect choice for the 415. Is what I used. Just get some good strapping tape to hold it in.
vr6cj is offline   Reply With Quote
Old 03-02-2009, 08:01 PM   #20257
STLNLST's Avatar
Glad it worked. It's one of the lowest profile batteries out. I think it will even fit in a Xray
Old 03-04-2009, 10:08 AM   #20258
STLNLST's Avatar
After seeing the tray offered by Stormers I still think that the Bitty design tray is the best option. Even though it pushes the battery way out and side impacts will be a concern of mine it seems to be the only option that will allow you to run "ALL" lipo's currently available. The Stormers tray angles the battery which runs into problems depending on the size lipo used. You also have to shave the bulk head screw slightly for battery clearance. The Thunderpower 3200 fits but the Orion 3800 didn't. The humps from the Orion pack also seems to sit the pack higher than the flat packs.
Old 03-04-2009, 10:19 AM   #20259
linger's Avatar
Hey STL_Lick_Nuts, if the Thunderpower 3200 fits - so will the Thunderpower 4200 40C. They use the same case. You want to pack in the biggest battery you can fit.
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 03-04-2009, 10:54 AM   #20260
STLNLST's Avatar
linger_ing_smell-Dujuan runs the Thunder Power packs. I have to run the Orions If you went with the 5000 packs like most racers have the bitty design tray is the way to go. You hurt my feelings and if I don't win a club race it will be because of this very conversation
Old 03-04-2009, 04:57 PM   #20261
I think the tray I have will work with alittle dremeling. It wont take much to get a 4200 pack to fit or even a 5000 pack. The 3200 thunder power pack was pretty impressive to me! We will see how it runs out at Speedworld in two weeks!
Old 03-04-2009, 08:57 PM   #20262
TwoTone's Avatar
Quick question perhaps I missed somewhere. What is the internal ratio for a 415 MSXX MRE 07?
TwoTone is offline   Reply With Quote
Old 03-04-2009, 09:11 PM   #20263
STLNLST's Avatar
I don't want to do any dremeling so I can't use that tray I'm going to get the bitty tray when I get some extra cash.
Old 03-04-2009, 09:11 PM   #20264
STLNLST's Avatar
2.25
Old 03-05-2009, 10:01 PM   #20265
bigkoitat's Avatar
Trader Rating: 6 (88%+)
I just wanted to share what set up I have on my 415MSXX-MRE
I used the Josh Newman Reedy set up but with front yellow springs
and red rear springs, also .5 spacer under the rear suspendion mount spacer.
The set makes the car feel planted on unprepped sealed asphalt. So when I go to the races on the weekends the car has tons of traction with Soda/Water prepped on sealed asphalt. The reason I'm sharing this cause now my 415 and 416WE feels excactly the same!!! I'm just excited and wanted to share
JAWS
TRF-416WE & 416-X / DHW / TEAMRCR.NET
bigkoitat is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
