Old 10-21-2008, 05:15 AM   #20071
chrisk's Avatar
Trader Rating: 32 (100%+)
Does this tray comes with nylon velcro type strap? or we still need that glass tape?
it doesnt come with nylon straps just uses normal glass tape, i have been using mine for about 4 weeks now and it is great. It has also helped me with gaining a little weight running lipos and getting up to the correct weight to race. I also run a sheet of lipo lead inside the tray. I have a 415msx and use the yeah lipos, all has been good so far.
If you are getting from Greg at Feral batteries, i know it says out of stock but i am sure he will get them in again soon, he is pretty good just contact him by email or you can probably get him on the
http://www.rctech.net/forum/australi...cessories.html
i can recommend him on service
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 10-21-2008, 11:05 AM   #20072
edwintklee's Avatar
Trader Rating: 23 (96%+)
Originally Posted by -KilleR- View Post
If you want to have the measurement it will take sometimes before I go measure it. Kinda busy lately. What I did was grind and measure. Do it few times and you are done. It only takes 20mins.
dude, i worry i cannot file as nice as you . i prefer to send to machine shop...please a simple measure with out taking out the part,....just measure in chasis, its takes only 1 min to measure...thanks in advance...
I am a Red Star, Blue Star, Fans......
edwintklee is offline   Reply With Quote
Old 10-25-2008, 03:48 AM   #20073
piper48
Guest
Posts: n/a
Dimensions will vary depending on type of battery being used. I've got the MRE n ran into same problem with my checkpoint 4900. Machine shops charge an average $60-$100 hourly rate for service, your better off doing it yourself. Besides, a new bulk head only cost what? $28-$32? Like NIKE, Just Do It!!!!
Old 10-25-2008, 10:51 AM   #20074
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
i just file my bulkhead yesterday with that 6" bastard. Now my lipo fitts nicely Its eazy... 30 mins job, edwin you might wanna try it your self.
Just look out for that bastard Lol!!!
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 11-04-2008, 02:47 PM   #20075
s13evo's Avatar
can anyone help me with a final Gear ratio or Spur/pinion combo for the
TRF415MSX MRE. I will be using a 19t motor with lipo on asphalt track.
thanks
s13evo is offline   Reply With Quote
Old 11-04-2008, 04:45 PM   #20076
bigkoitat's Avatar
Trader Rating: 6 (88%+)
Yeah I used a dremel and alot of patience and got the Orion 5000 Platniums to fit.
bigkoitat is offline   Reply With Quote
Old 11-05-2008, 04:36 AM   #20077
s13evo's Avatar
thanks
doh
Old 11-09-2008, 02:01 AM   #20078
s13evo's Avatar
is 6.6 final gear ration to much for a 19T motor???
Old 11-09-2008, 09:22 AM   #20079
I12PonU's Avatar
Trader Rating: 10 (92%+)
dependds on your track
I12PonU is offline   Reply With Quote
Old 11-11-2008, 11:28 PM   #20080
kilokhan's Avatar
Can TA05 parts like
Diff joint,
http://www.rcmart.com/catalog/rc-ta0...th=595_744_720
or
OneWay
http://www.rcmart.com/catalog/rc-ta0...3-p-15046.html
Or
Spool
http://www.rcmart.com/catalog/rc-ta0...7-p-16379.html
Fits 415 ?
kilokhan is offline   Reply With Quote
Old 11-12-2008, 01:38 AM   #20081
berserk's Avatar
Default spool
im using the TA05 spool on my 415. it fits perfectly.
berserk is offline   Reply With Quote
Old 11-12-2008, 10:33 AM   #20082
I12PonU's Avatar
415 front diff is centered and 05 diff is offset, did you just mount the pulley on the opposite side?
Old 11-12-2008, 11:33 AM   #20083
94eg!'s Avatar
Trader Rating: 17 (100%+)
...Plus the 415's bulkheads are spaced ~4mm further appart...
94eg! is offline   Reply With Quote
Old 11-13-2008, 04:14 AM   #20084
chrisk's Avatar
i use the lower arms on my 415msx #51104, i was recomended to try the shorter arms are these part number #53928?
i was told they help with grip, is that correct?
do you put the shorter arms on the rear or both front and rear?
if so what suspension blocks do i need to use, when i try the shorter arms?
is any body using these shorter arms?
smaracing.org
Old 11-13-2008, 08:38 AM   #20085
94eg!'s Avatar
Yes those are the arms. There is also kit 54083 (about $60-70 on eBay) featuring the 416 uprights, axles, larger wheel bearings and other parts. This is supposed to be a conversion for the TA05, but it should work on any car. I can't comment on what blocks you need. Yes they would have ot be wider ones. You may also have to worry about your axle length with this kit.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
