Like Tree3Likes
Tamiya TRF415
Old 04-22-2008, 06:17 AM
  #19696
pug 205 gti's Avatar
i just drilled a 2.1mm hole through the centre of mine so i can just squeeze in my 2mm wrench.it works a treat.
pug 205 gti is offline
Old 04-22-2008, 07:39 AM
  #19697
tc3team's Avatar
I'd be wary of spinning up the drill too much and distorting the plastic but it sounds like a good idea if you use a low speed drill
tc3team is offline
Old 04-22-2008, 07:46 AM
  #19698
i was careful with the drill lol
i saw this done on reinhards car so i just tried it out
Old 04-22-2008, 07:49 AM
  #19699
tc3team's Avatar
I'll use the tried and tested way of using a knife first I think... (he says, slicing his finger off in the process )
Then if im not in a doctors surgury or hospital i'll set myself loose with the drill
tc3team is offline
Old 04-22-2008, 09:19 AM
  #19700
Here this is a nice pic of some drilled/cut ball joints
Old 04-22-2008, 10:10 AM
  #19701
zenithrr's Avatar
hey everyone, I rearranged my 415msx for the summer and tried out some new setup.
1. switched from a futaba mini 9650 (26g) to airtronics ERG-WRX (60g)
2. moved the 5 cell batteries from align the back to the front.
3. moved the balance weight (about 25g) from the battery side's rear to battery's front(top)
handling before: the car's rear end slides a lot. extrmely respond, but easily loss control if not careful; must push out to exit the conner otherwise would spin out. !!!who said add more weight to the rear could improve traction.!!!
handling after: the car turn in a bit slower but the front end is firm to the ground, the rear don't push out to the front anymore. while within the turn the car is very predictable with it's patch whether you give it gas or brake. the exiting speed is a little downward because the rear wheel spin out a bit, but no problem at all the front wheels get more of the traction pulling straight the car, and always stay in it's path very nicely like a fwd. very forgiving style of handling now.
I am using the 26mm/30mm F/R setup, I think the bushless pulls it even better. it's a bit like my zx-10r now, shooting out like a bullet. (when the surface allowed)
zenithrr is offline
Old 04-22-2008, 08:43 PM
  #19702
Default WHICH ONE TO GET?
HI GUYS,
IM THINKING OF GETTING A TRF415MSXX AND I DONT KNOW WHICH ONE TO GET. CAN YOU GUYS SHED SOME KNOWLEDGE AS INTO WHICH IS A BETTER BUY THE MRE EDITION OR THE STANDARD?
CHEERS
Racers Concept is offline
Old 04-22-2008, 08:59 PM
  #19703
zenithrr's Avatar
MSXX MRE's rear upper deck is separation type. lighter and look better for my sense. you can aalway upgrade to the MRE's upper deck like I did. no cost more than $20
zenithrr is offline
Old 04-23-2008, 02:11 AM
  #19704
TRF415boy's Avatar
If you had asked we would have told you right from the start to put your pack at the front...
TRF415boy is offline
Old 04-23-2008, 03:03 AM
  #19705
TryHard's Avatar
ed do you know if these will work on the msx mre thanks
http://www.muchmoreracing.com/store/...roducts_id=322
Yup, certainly seem to be the right spec.
TryHard is offline
Old 04-23-2008, 01:06 PM
  #19706
Hedaria's Avatar
Default Rubber tire setups
Anyone have some rubber tire setups for asphalt? 13.5 brushless, Euro style track... I do have the spool, one way and diff options for the front. I really prefer to run a front diff. So the type of setup I'd like is something pretty neutral, not so much on the edge.
Hedaria is offline
Old 04-24-2008, 11:25 AM
  #19707
guys, i couldn't source a msx front oneway, is there any alternatives? ta05? tb5? msxx?
Molala3 is offline
Old 04-24-2008, 11:31 AM
  #19708
Hedaria's Avatar
Default 415MSX One way
Molala3, you have a PM re: one way
Hedaria is offline
Old 04-24-2008, 01:39 PM
  #19709
Kwikvdub's Avatar
Trader Rating: 100 (100%+)
Hello, Is there a difference between a D block and a 1D block??...... Just wondering?
Thanks!
Kwikvdub is offline
Old 04-24-2008, 01:58 PM
  #19710
kwikvdub. try eds website,http://www.thard.co.uk/excel.html
what vw have you got?
