Old 12-04-2006, 02:54 PM   #16606
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
guys i wud like to ask if somebody ran a spool in front and rear??? is it possible??
nikkiesteban is offline   Reply With Quote
Old 12-04-2006, 04:23 PM   #16607
HarshGuy's Avatar
Originally Posted by Rogier
Do you have a part#??
Tamiya 53947 TRF415MRE Front one-way housing
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 12-04-2006, 07:05 PM   #16608
Yes...Its possible if you're only running in a straight line...
Ben.C is offline   Reply With Quote
Old 12-05-2006, 12:40 AM   #16609
Wing Chun's Avatar
Originally Posted by HarshGuy
Thanks Harshguy, But only 6 pages came through.
Addam
Wing Chun is offline   Reply With Quote
Old 12-05-2006, 02:30 AM   #16610
TryHard's Avatar
thats because the MRE instructions are a suppliment to the MSX ones.... build the car as the MSX, but follow the MRE bits where required.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 12-05-2006, 05:31 AM   #16611
lol
but what is the main advantage of oneway to spool?? and what is much better at rear ??? rear differential or rear ball differential??
Old 12-05-2006, 06:31 AM   #16612
Wing Chun's Avatar
AAAAHHHH
Thank's Tryhard.
Addam
Old 12-05-2006, 06:38 AM   #16613
TryHard's Avatar
lol
No offence, but given that every single TC avaliable on the market comes with a rear ball diff, that should answer your question on that.
A oneway gives a much higher level of steering into a corner than a spool does. The front wheels are allowed to freewheel, which means they can give a greater proportion of their avaliable grip to cornering forces, rather than traction. However you do loose front braking, effectively meaning you apply a handbrake when braking with a one-way (not good).
Usually, the fastest lap times will come with a one-way, however they can be hard to race other cars with, as there is normally only one line you can run. They are good for indoor when running rubbers, and large high speed outdoor tracks.
A spool works by locking the two axles together. This takes away some turn-in, but gives loads of mid-corner to exit, on-power steering. effectively the front of the car pulls the rest of the car out of the turn. And you still have braking ability, and it is much easier to turn consistent laps and race other drivers with a spool. Mainly used outdoors on asphalt, with rubbers.
A front diff is kind of the middle ground between the two. With foams indoors, or very tight and twisty indoor rubber tracks.
Hope that helps.
Ed
Old 12-05-2006, 08:01 AM   #16614
Rogier's Avatar
Thanx! Which pulley do you use? The one of the TA05??
My RCTech trader feedback: http://www.rctech.net/forum/trader-feedback/146331-rogiers-feedback-thread.html
Rogier is offline   Reply With Quote
Old 12-05-2006, 10:45 AM   #16615
Charles Godwin's Avatar
For us UK lot :
I'll be competing in the BRCA 19t series this year coming and if it isn't such a big question to ask can you guys/gals advise me on gearing for these tracks please , i'll be using mainly the Atlas (Blue can) and C2 (Silver can)
Snetterton
WLRC
Southend
Bedworth
Wrexham
Stafford
Cotswold (i've got a gearing for this with a Atlas but would also like a gearing on a C2)
Cheers, Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 12-05-2006, 11:32 AM   #16616
stuey's Avatar
atlas about 5
c2 about 5.4
stuey is offline   Reply With Quote
Old 12-06-2006, 05:15 PM   #16617
Burlap's Avatar
Send a message via MSN to Burlap
Originally Posted by veecee
Just purchased the following on a recent trip to HK to do the job:
4024004 MRE Upper Deck
9404668 MRE Lower Deck
9804266 MRE Steering Posts
3454396 Steering Bridge
9808066 Steering Arm
2x 3x42mm turnbuckles and 1x 3x23mm turnbuckle. All the parts totalled around AU$120. Good luck mate.
Any updates on you running this MRE conversion veecee?
Burlap is offline   Reply With Quote
Old 12-07-2006, 05:43 AM   #16618
Default spool help
I bought this Jaad spool from Precision and no problems fitting except it 'chatter' on steer while on power. Is this normal for a spool? Thought there's something wrong with my 1150 bearings but when I fit the one-way back chattering disappears on steer on power.
Appreciate any help.
Originally Posted by TryHard
Hey guys, just thought I'd direct you lot to the new link in my sig (JAAD Racing). I have a few of their parts for the 415 on order(currently available through Precision RC), looking forward to trying them out, certainly look good.
Oh, and can anyone spell shameless plug???
Cheers
Ed
Edgarski is offline   Reply With Quote
Old 12-07-2006, 05:50 AM   #16619
sohlman's Avatar
Trader Rating: 89 (100%+)
The chatter is normal for a spool.
Steve Sohl
sohlman is offline   Reply With Quote
Old 12-07-2006, 06:34 AM   #16620
TryHard's Avatar
same as Sohlman... it will be worse becuase of the steel outdrives (would be less with Delrin). I ran steel outdrives outdoors last year, and there were no ill affects. Personally I prefer steel from a durability standpoint.
HiH
Ed
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
