Old 11-29-2006, 06:45 AM   #16576
Trader Rating: 21 (100%+)
Default Gotcha
Originally Posted by TRF415boy
Too much ackermann on the MRE, move the steering link on the rear hole on the hub it will calm the car down a lot. Don't forget to reset your EPAs.
I hear ya.Will do the D block 1st..see how it feels..That would be next.Will do the epas too.Running it down at 70% now.Thanks,Mario.
lotus1 is offline   Reply With Quote
Old 11-30-2006, 01:14 PM   #16577
Send a message via MSN to piereson
Hi to everybody,
I am a new consumer of this forum.
My car is Tamiya TRF415 MSX-MRE and me I have a problem:
I have attentively followed and with a lot of care the instructions, but my car has the chassis folded up.
The chassis is ok, when I end the assemblage the chassis he slightly remains folded up.
You excuse me, I don't speak well English...
To someone of you the same problem happens?
Thing I have to do for resolving?
Thanks you!
piereson is offline   Reply With Quote
Old 11-30-2006, 02:09 PM   #16578
WRXTC's Avatar
Sounds like you have a tweak problem? Undo all the screws on the chassis so they are loose and let the car sit over night, then tighten them up again. If it is tweak it should get rid of the problem.
WRXTC is offline   Reply With Quote
Old 11-30-2006, 03:08 PM   #16579
Charles Godwin's Avatar
Un screw all screws slightly, then tighten them all back up again except the top deck screws. Place the chassis on a flat set-up board then push down the lower chassis deck, at the same time tighten the screws in the top deck in a 'X' pattern.
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 11-30-2006, 03:53 PM   #16580
I have already done this but me I have not resolved the problem.
Old 11-30-2006, 06:55 PM   #16581
dodo's Avatar
Send a message via Yahoo to dodo
try to unscrew the upper deck, let the car rest on something (car stand for example) and not on its suspensions overnight. this will let the lower deck to straighten up. After that you can screw back the upper deck as per Charles Godwin method posted above.
dodo is offline   Reply With Quote
Old 12-02-2006, 02:24 PM   #16582
chris_morrison_'s Avatar
Hi I'm a proud new owner of a new Tamiya MSX MRE kit and i'm wondering if anyone knows the tows associated with all the Suspension Mounts.
Thanks in Advance
Chris Morrison
chris_morrison_ is offline   Reply With Quote
Old 12-02-2006, 03:01 PM   #16583
If you go onto Tryhard's (Ed) website there will be a excel sheet of all the toe in/outs.
Charles
Old 12-02-2006, 03:57 PM   #16584
Wing Chun's Avatar
Default Please help
Hi Guy's
Both myself and 2 friend's from our track have had major problem's keeping the wires on the V2 motor.We are all using MSX's, Every race meeting we have the motor wire's come off. We have all resoldered the wire's , cleaned the end's for good contact. All running heatsink's. Does anyone else have the same problem. It seam's to be a issue with the endbell. The motor's get around 80/85 temp. Is there such a good thing as a good ratio for a 7x1 motor on a open, wide, fast track with several technical corner's to it.
My car I thought I had it sorted out. The car is super fast and handles well.
My motor is a orion,
7x1, with a 61,000 rpm the motor is set at 6 degree's advanced.
My ratio is 102/28
7.967
Rollout 24.843
The 2 other guy's car's are pretty much the same setup's, except one has a 8x1 motor.
Do any of you guy's have any idea's please.
I have come to ask the god's of the R/C world here for help please.
Addam
Wing Chun is offline   Reply With Quote
Old 12-02-2006, 04:09 PM   #16585
tbeardmore's Avatar
Try getting a Team Tamale Fan Mount and running it on the endbell....
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 12-02-2006, 04:42 PM   #16586
Mi2_Tastic's Avatar
HI I'm running the Tamal fan mounts and I'm looking at a 10-20 deg(c) drop in temp on a run, this is giving me temps in the mid 40's which means that I can gear up and not have to worry too much about wires becoming unsoldered.
Mi2_Tastic is offline   Reply With Quote
Old 12-02-2006, 07:24 PM   #16587
TryHard's Avatar
deffiently sounds like you need some fans on there.... I'm using the Tamale mounts now too (that makes three ), which help.
TBH, just try and get some fans so that they are directed at the motor wires, that should helps loads. Even if it's just a fan servo taped to the chassis, that'll help.
Make sure it's wired into the batteries though, as that will give the most consistent voltage to the fans. Good fabs to get are the Much More ones, or the Cool Can Fan ones (more expensive, but smaller).
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 12-02-2006, 07:26 PM   #16588
Wing Chun's Avatar
Thank's Guy's
Do any of you know where I can buy one from please.
Thank's
Addam
Old 12-02-2006, 07:33 PM   #16589
Wing Chun's Avatar
Hi Guy's
This is the fan I am running and it seemed to work really well at first, I was hit in the side and the fan is fine but it started getting hot after that. Both fan's still work though.
Addam
Old 12-02-2006, 11:11 PM   #16590
bender's Avatar
Originally Posted by TRFMAD
Hi Guy's
Addam
Addam,
To be honest you're going to have a hard time keeping those wires on as we get into our hot summer months. I saw a couple drivers prior to the Nats have the same problem due to the heat.
I know it's untidy but I suggest you simply run as many fans as you can fit in there - I've seen quite a few cars with 3 or more fans
Another alternative is to solder some corally tubes onto the motor and use corally plugs - that might be more tolerant of heat before it comes off.
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
