Old 04-16-2007, 03:05 AM   #18106
veecee's Avatar
Trader Rating: 34 (100%+)
I'm still struggling to get my car to turn-in with a spool running mod (Mamba Max 5700). Running a Numan-based setup with 2 degree rear toe, MRE steering, short arms and it's still push city entering a corner... Good mid-corner and exit steering though. I might have to put the one-way back in...
SMOKEM --- XPRESS --- MONTECH --- SRT
veecee is offline   Reply With Quote
Old 04-16-2007, 07:38 AM   #18107
rampal's Avatar
Send a message via MSN to rampal
Hi all:
Just get an MSXX from my wife (oh god, I'm so in love with her ) and it comes with a double one-way. The thing is that I never have a one way before and I usually run outdoor asphalt rubber mod (there is no really stock here in spain). The thing is that I'm thinking on getting rid of the dual one-way and get the MRE spool... or a front diff (I need brakes!!). And I would like to have them as complete parts (for easy changing)
which are the parts do I need from the MRE to do that? Can I put a rear diff on the front (I have a couple from my TA05 ready for action)...
I think that for this mod I need:
for the front:
3454401 direct holder
9804268 direct cup
9804267 direct coupling
for the center
3454395 Direct center shaft
51213 TA05 16T pulley (2 units)
3455643 spur gear stopper
5mm e-clip
is this correct? Is there any way to get these in complete packages (like Ikea )
thanks a lot!!!
al
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 04-16-2007, 08:51 AM   #18108
Thanks for posting.
Do you know what the HPI springs equal in Tamiya ?
Originally Posted by TRF415boy
Hi guys,
First meeting outdoors of the season, I made a few changes to my setup from last year and it seemed to have worked quite well.
I ran this setup with a 12T in and in 5-cell 3.5T b/L (using a XA block at the back to get 3deg toe in) and I equalled my track record on 6-cell mod on that track.
Then on sunday used it to take 3rd qualifying spot at TORC in 19T, bearing in mind I didn't have much HP compared to the 2 front runners.
It's basically a MSXX setup, with adequate springs and the short LW suspension, and the rear RC blocks raised 1mm to try and get a more even wear on the front and rear tyres, and get a few more good runs out of new tyres.
Worked well as I did my best run in qual 3, on 3rd run tyres and at the hottest part of the day. No drop off in the two finals either using the same tyres.
Andyg01 is offline   Reply With Quote
Old 04-16-2007, 09:59 AM   #18109
Do anybody know what the part numbers would be for the white belts I can fit on my 415 MSXX.I cant seem to find the belts anywhere.Thanx for all the info.
TOP Racer is offline   Reply With Quote
Old 04-16-2007, 12:10 PM   #18110
TryHard's Avatar
Originally Posted by rampal
Hi all:
for the front:
9804268 direct cup
for the center
5mm e-clip
thanks a lot!!!
al
Hi yup thats correct... although you'll also need some 2x9.8mm pins to lock the drive cups to the spool centre. Part# TAM9805776. Of course you could just use some axle ones, and grind a little off the end to get them too fit.
I don't actually know of anywhere that has all the parts as a complete package though.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 04-16-2007, 12:32 PM   #18111
quantum's Avatar
Originally Posted by Burlap
I race on asphalt mainly, and found the car less twitchy on the short arms compared to the long arms.
Also the short arms are far more stronger than the long arms, and don't snap as easily. For example I have been running the same short arms as what I originally reassembled the car with, and been racing the past two months. No broken arms at all. Same period I would've been through at least 3 long arms.
thanks to burlap, eirik, tryhard and everyone else that responded.
it sounds like durability and precision are key factors. does the msxx include long or short arms?
and does anyone think the long arms are better??
quantum is offline   Reply With Quote
Old 04-16-2007, 01:05 PM   #18112
rampal's Avatar
long arms are included on msxx.... sorry but cannot say anything about durability yet...
Old 04-16-2007, 01:31 PM   #18113
TryHard's Avatar
Speedtech has both the front and rear MRE/MSXX belts in stock.
http://www.speedtechrc.com/store/ebp...?catmainid=521
HiH
Ed
Old 04-16-2007, 08:54 PM   #18114
maxepower's Avatar
Unhappy RE:Understeering woes!
What spool are you using? The Tamiya MRE spool?
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 04-16-2007, 09:46 PM   #18115
veecee's Avatar
Just a cheapie from Shooters as I'm still toying with a spool.
Old 04-16-2007, 09:57 PM   #18116
linger's Avatar
Where can I get the parts to piece together an MRE spool? I can't seem to find them anywhere??!!??
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 04-16-2007, 11:03 PM   #18117
Trader Rating: 15 (100%+)
LIng king dong , check with the kid that bought javiers car ..he should have a few .I left the one i had in his stuff.see if he will sell one.
AARON YOUNG is offline   Reply With Quote
Old 04-16-2007, 11:42 PM   #18118
TRF415boy's Avatar
That could be your problem, spools with delrin outdrives provide a much better turn in and mid corner steering than ones with steel/aluminium outdrives.
TRF415boy is offline   Reply With Quote
Old 04-17-2007, 12:07 AM   #18119
Eirik's Avatar
Eirik is offline   Reply With Quote
Old 04-17-2007, 12:19 AM   #18120
linger's Avatar
Originally Posted by AARON YOUNG
LIng king dong....
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
