Tamiya TRF415
Originally Posted by lotus1
Thanks,Mario
HiH
Ed
boredom at work
Originally Posted by TryHard
Not sure if you spotted my reply above... but MRE comes with B/A for the front, and XB/D for the rear... You'll need an extra D block, and a D-Bridge block, and thats it for the IIC setup (D/D-bridge front, B/D rear)
HiH
Ed
HiH
Ed
TRF 415 MSX MRE Internal Drive Ratio
Hi,
Can any else confirm the internal drive ratio of the MRE??
I have been beleiving iit was 2.187.
Where did the 2.25 come from?
C.
C.
Originally Posted by CRiXman
Hi,
C.
C.
I did.I was trying to quote you and quoted myself. That's what the Thanks was for. This sitting around on standby at work drives me nuts.
Carl has it correct for the internal ratio. Despite the new pulleys only having 18t, it is really 36, given every other one has been removed. On the old pulleys it was 35t. The centre pulley is still the same size.
35/16 = 2.1875
36/16 = 2.25
HiH
Ed
Originally Posted by Carl Giordano
Diameter of the new pulley is equal to diameter of the 36T white pulley. 36/16=2.25
The MSX has 35T/16T= 2.1875
The MRE has 36T/16T=2.25
However the MRE pulleys have twice as less teeth (18T)... this is for less friction I beleive?
Thanks again..
C.
Would it be possible, or worth it to swap out the pulleys on the MSX for the ones on the MRE? Would it even be possible?
Can you use the 415MSX conversion kit on the original 415? Also do you have to use the reversible suspension or can you use the standard suspension?
Thanks,
Thanks,
This is what it says on their website:
*Compatible Chassis: TRF415MS, (also TRF415 equipped with reversible suspension
I have a conversion kit for sale if you're interested
You have PM. Interested in the conversion kit.
Thanks,
Thanks,
Hey Guys, I have been racing nitro cars for a while and just getting back into racing electrics. it has been a while and lost in touch with electric world.
I decided to get a tamiya after all the research but can decide between MSX or MRE, I will be racing on asphalt, which should I go with?
also any suggestion on what kind of battery is best to race stock or 19t? I see the batteries are up to 4200 now and most are IB, the last time I run electric we where using GP 3300. and in regards to motor do I want to go with brushed or brushless now? I have not been to any tracks yet so I dont know if now you can mixed them up or most run separate class.
I will be hitting the LHS this weekend and your input is appriciated
Thanks!
The MRE would be one up on the MSX. The MRE has very stock setting.
You wouldn't go wrong on the IB 4200 World Champ Edition.Very high wotage and very low IRs, by the way if you're looking at Li-POs,you can put that thought aside 1st as the MRE can't fit the LI-PO cells, unless you want to spent more on a new right side bulkhead to fit stick packs.
If you want to run 27 turn or 19 turn, then stick to the brush ESCs although brushless ESCs can take brushed motor but they are 'BIG'. But brushless seems to be the way of the future though...
Hope these helps.
If you want to save money, the MSX is an excellent car, and performance wise their is not much difference. You can also get a stick pack conversion kit for the MSX, that will allow you to fit a lipo pack if you decide to go that route.
Bottom line - They are both excellent cars, you will not be disapponted with either one.
