Tamiya TRF415
Originally Posted by Burlap
I have looked back the past 10 pages and found nothing, who has been using Evo V arms on their MSX?
I am looking at getting the arms and 42mm uni shafts, but anyone else tried the different toe blocks method? Part numbers if possible please.
http://rctech.net/forum/showthread.p...ms#post2659137
http://rctech.net/forum/showthread.p...ms#post2662543
I'm going to give this a try soon...
Originally Posted by veecee
These posts should answer your question:
I use the short arms on my MRE and I found the car works very well with them. Curently I hold the track record by almost an entire lap!
can i ask a favor here guys..?
can someone please send me a trf 415 decal sticker? scanned trf 415 sticker that's included i think in the kit. thanks a lot... [email protected]
Crazy Suspension Blocks
Yes; Tamiya Suspension Blocks are crazy. They should just mark them with a normal number.
I was looking for a Tamiya Suspension Block Chart. I want to set 2-Degrees Rear Toe-In on My TB Evo 5.
Take Care
Take Care
Check out tryhards website, best place to find info on suspension blocks. download his excel file, and your done
check the excel section on my website, there is a chart in there.
Basically, the blocks are actually quite logical, once you get your head round it. The reason for the (slightly) odd systems is that the X series came out after the 2004 worlds, and Tamiya had been using A, B, C etc for marking the block width on the 414 for at least 2-3 years already... would have been more confusing to change it...
Anyway, from narrowest to widest. Each block gives 0.5° toe difference,
XD, XC, XB, XA, X, A, B, C, D, E
For two degrees on an Evo5, try A/E or X/D (Front Rear / Rear Rear). X/D will give the car (slightly) more grip on power, and allow it to rotate quicker in the middle of the turn, as it has a narrower track width (distance between the tyre centre lines).
HiH
Ed
HiH
Ed
i ordered my TRF415MSXX today. i should have it in the next 3 days. i am so amped now. I am so looking forward to building the car. i will be asking alot of questions, so prepare yourselves. i will post some pics of the build if you guys don't mind too
Is the msxx just a MRE with out all the ti stuff, a oneway and a new top deck??
Yep basically, but it also comes with the aluminium air duct.
Charles
Charles
when is it gonna be out here in the USA?the msxxx?
Hey TryHard; Thanks for the info.
It looks like the best thing to do is to get all of the Suspension Blocks and Tune your kit from there.....?
-Those Suspension Blocks cost about $11.00 - $14.00 each.
Take Care
Take Care
Does anyone where i can download a 415 manual?
http://www.tamiya.com/japan/rc/rcman...4trf415msx.pdf
what essentail setup tools do you all use.to set your cars up?
im looking in to getting a hudy all in one sytem.
but would like to hear alternatives on this?
thanks
thanks
