Tamiya TRF415
#9991
Originally Posted by Mafodda
Hi to all,
can someone give me a killer setup for my MS with 26 mm. foams on outdoor asphalt ?
Or some guidelines about springs,oil,roll center,etc. ?
Ideal setup must be near setups with rubber on asphalt or similar to setups with foams on carpet ?
If you have experience with foams please help me ....
Thank you in advance to all !
The reality is running foams on asphault has so much traction it almost doesn't matter what your setup is....the cars just stick.
#9992
Thanks, Nexus.
#9993
#9996
Originally Posted by Blue Sky
What foams is everyone using? I put on a set of Parma and the front wheel is hitting/rubbing the knuckle's servo arm big time. Thanks.
I run my 415 w/ LW suspension this way and can fit Parma, TRC, Jaco, GQ, ect, ect...
#9999
Do the pro 4 knuckles use the same bearings as the tamiya ones? Also are they a good choice for repacement if you cant get the tamiya ones?
If I'm not wrong,the bearing used on the pro4 knuckles are larger than the Tamiya.Meaning that its heavier,but on the plus side its more enduring than the tamiya ones.
SOmeone verify my statement for me...Thanks...
Yes, the Pro 4 hubs use a larger bearing.
Thanks Jack for verifying that for me.
So yes they are larger and probably a bit more durable then the stock setup. I've heard that other racers are using them even if they don't run foams to get a bit more steering and/or durability.
I know some of the TRF drivers uses them.
Do they really give that much more steering??Do they use it when they use a spool or the normal front one way??
Thanks for any info.
I do believe that David Spashett and Adam Rogers used them at the KO GP, and Marc R at the euros used the Pro4 Hubs. If you look at there cars, the steering links are in the rearward holes, whilst the hubs themselves distinctly look like the pro4 ones.
Actually waiting on response to the Q about the advantage of them...
HiH
Ed
HiH
Ed
