Like Tree3Likes
Tamiya TRF415
Old 08-15-2006 | 11:17 AM
  #15136
JayL's Avatar
R/C Tech Elite Member
carpet:new short evo 5 ones:53928
ya, I think the lighter sway makes it roll and work alittle better
JayL is offline
Old 08-15-2006 | 03:57 PM
  #15137
Burlap's Avatar
Originally Posted by buboy28
i think Steve of SPEEDTECH RC ca help you out if not try RC CHAMP
Champ were out of stock and it is too expensive to get something shipped from USA to Australia.
Burlap is offline
Old 08-15-2006 | 05:09 PM
  #15138
JAY_UK's Avatar
What works best on carpet with rubber - 4 degree or 2 degree castor blocks? Car is new MRE.
Cheers Jay
JAY_UK is offline
Old 08-15-2006 | 05:40 PM
  #15139
hierog's Avatar
JayL - nice meeting you too. it's awesome to see so many Tamiya's out there at speedworld now! It only took 5 years for everybody to jump on the bandwagon!
My car was running great after you suggested the block change, and i drove just well enough to pull out the win.
Now I've got to get my MSX working as well as my EVO IV -
Harsh, you looked pretty good out there too, glad you're loving the new ride!
thanks for the help
vic
hierog is offline
Old 08-15-2006 | 10:12 PM
  #15140
Cheers Jay
Really depends on the size and the tpye of track you'll be running...
Mostly we would use the 4 degree caster block.
Ben.C is offline
Old 08-17-2006 | 06:38 AM
  #15141
diesel's Avatar
Hi there,
Are the following parts right for a oneway conversion on the MRE?
1) RC TRF415 Fnt One-Way Housing
http://www.tamiyausa.com/product/ite...oduct-id=51059
2) RC TRF415 LW One-Way Cup Joint - Lightweight
http://www.tamiyausa.com/product/ite...oduct-id=53704
Any other items i missed for the conversion? (New to tamiya's 415 series)
Thanks,
Diesel.
diesel is offline
Old 08-17-2006 | 09:57 AM
  #15142
I've been having trouble with my car. On power steering wasn't very good so I changed my droop setting which gave me the on power steering i was looking for but now when I get on the throttle out of a turn, the rear wants come around. I haven't been able to get a good balance of steering and grip. Does anyone have a suggestion of what to try next.
Also, is moving the rear arms back on the 415 supposed to give you more or less rear grip?
DOTMAN is offline
Old 08-17-2006 | 03:41 PM
  #15143
maxepower's Avatar
Talking RE: SET-UP
I believe more rear traction!
Did you change the droop in the front or both?
You might have gone to far! How much did you change? You should always have a little more droop in the front then the rear! A lot more depending on what tires your running.
Be consistant if you change the droop, don't change anything else or you won't get a good feel of the changes you made. For example, don't rotate the tires or change ride height or shock location. One step at a time and you will feel the result of that change you made. Small steps Grasshopper!
maxepower is offline
Old 08-18-2006 | 08:49 AM
  #15144
Carl Giordano's Avatar
Can someone provide the part number for either the powder blue or white spring set? Looks to finish-up my outdoor ride...I know its late in the game but what the hell...Thanks
Carl Giordano is offline
Old 08-18-2006 | 09:11 AM
  #15145
HarshGuy's Avatar
White spring set - 49382
HarshGuy is offline
Old 08-18-2006 | 02:46 PM
  #15146
stegger's Avatar
What are the differences in the 415, MS, and MSX chassis's is it just thicknesses or are there other things.
stegger is offline
Old 08-18-2006 | 02:51 PM
  #15147
nordheim's Avatar
Milky white spring set (blue tint) 49389
nordheim is offline
Old 08-18-2006 | 02:52 PM
  #15148
nordheim's Avatar
lots of things.
nordheim is offline
Old 08-19-2006 | 12:28 AM
  #15149
DOMOisCOOL's Avatar
Can someone tell me the exact part numbers from Schumacher or Xray to make a battery brace/bar for the 415?
DOMOisCOOL is offline
Old 08-19-2006 | 04:31 AM
  #15150
kewdawg's Avatar
Guys.
Just bought a front diff on Ebay, for this year's carpet season, which seems to have started prematurely - around here. Can someone tell me what suspension blocks give 3 degrees of front inboard toe and 1 degree of rear inboard toe using the standard o degree rear hubs (I, still, haven't quite figured out the chart, yet)? Also, which sway bars work with the 415? Is it the TA05 or the Evo V?
Thanks in advance.
kewdawg is offline
